Check Engine Light
Old Sep 18, 2007 | 07:03 PM
odamsr's Avatar
Check Engine Light
I just had the head gasket replace and I have been driving it for about 2 days and today the check engine light came on. I am going to check it tomorrow after work. My question is could it be something serious that would damage the engine if I drive it tomorrow.
Thanks
Shannon
Old Sep 18, 2007 | 07:14 PM
Jay351's Avatar
Check the code to find out waht it is.
Then remove your battery contacts for 10 mins, then drive it, if the code comes on you defently have a problem, if it goes away then it was a ghost code.
Old Sep 18, 2007 | 07:36 PM
odamsr's Avatar
Thanks! I can't get to checking the code till tomorrow afternoon.. Just making sure that I wouldn't damage anything by driving it.
Old Sep 18, 2007 | 07:40 PM
Jay351's Avatar
well it depends what the code is for silly
Old Sep 18, 2007 | 07:55 PM
thook's Avatar
From the sound of it, I'll bet it's pretty serious... (<<<wiseass)
Old Sep 18, 2007 | 09:23 PM
86tuning's Avatar
Did you replace the knock sensor wire when the head gaskets were done?
Old Sep 19, 2007 | 04:23 PM
odamsr's Avatar
Yes I replaced the knock sensor and wire. The code is 71 which is EGR System malfunction. Isn't this for CA only?
Old Sep 19, 2007 | 05:23 PM
86tuning's Avatar
Possible misrouting of the 1234134 million vacuum hoses
Old Sep 19, 2007 | 07:11 PM
odamsr's Avatar
thanks.. I will double check all of the lines this weekend when I replace the starter..
Old Sep 19, 2007 | 09:20 PM
Jay351's Avatar
Did you clean our the EGR valve?
bigjstang
Jun 2, 2025 03:56 PM
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
colinmil
Jul 6, 2015 04:03 PM
