CV Axle replacement help
Old Sep 28, 2007 | 02:59 PM
1990arizona4runner's Avatar
I am replacing my half shafts on my 1990 4runner 4x4 and am having trouble removing the cone washers from the front wheels. Any suggestions. I tried using a tapered punch but that wasn't working at all.
Heres a pic of what im talking about.
Old Sep 28, 2007 | 03:30 PM
MudHippy's Avatar
Search "cone washers".
Here's a good thread with lots of different ways described.
https://www.yotatech.com/forums/f116...l-hubs-118905/
Old Sep 28, 2007 | 05:44 PM
eric-the-red's Avatar
I found tapping on the side of the hubs with a hammer worked, not hard enough to dent them but not too lightly either. And leave the nuts on the end of the studs a couple of turns, trying to find the cone washers after they shoot off at Mach 1 can be a PITA.
Old Sep 28, 2007 | 06:06 PM
thefreqofnature's Avatar
Yeah...what Eric said. Take about a 3 pound sledge and hit the hub right above the stud. Be sure and have the nut on the hub. I can see a bit of a flat spot in your pic where it looks like it's been done before. Put anti seize on them when you replace.
I replaced the studs on the front diff flange with bolts so it's real easy to replace the CV's next time. Good luck
Old Sep 28, 2007 | 08:08 PM
Thanks guys. Thats not actually my pic, I stole it from somewhere else to help get the point across. Im trying that first thing in the morning
Old Sep 28, 2007 | 08:45 PM
thook's Avatar
Just a suggestion.....
A 3lb'r will work, for sure. But, I've just used a ball peen hammer (flat end) resting against the hub above each washer/stud (with the nuts on) and then strike that with another hammer. Seems to have less impact on potentially ding'n up the hub and much less chance of accidentally striking a stud. Of course, PB Blaster first...
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
ItsJustD
Jul 7, 2015 07:49 AM
toyoda8488
Jul 5, 2015 10:18 PM
