Gear ratio math
Old Sep 23, 2007 | 11:16 AM
justinking060310's Avatar
Gear ratio math
ok, I got the front diff out of a 94 p/up 22re 5 speed - I used a punch and marked a tooth on each; the pinion and the ring, and then counted 3 times to make sure I got the same number everytime.
It has 42 on the ring and 11 on the pinion. Do I understand the math correctly that you divide 42/11 to get the ratio? that equals 3.81 - can that be right? seems odd to me.
EDIT - Pictures, cuz everyone likes pictures
Old Sep 23, 2007 | 11:25 AM
mt_goat's Avatar
Are you sure you counted the pinion gear teeth and not those spider gears?
Old Sep 23, 2007 | 11:31 AM
yes, they are way in the back, had to look through the bottom. I am positive I counted the pinion
the axle code in the jamb is B03A - which toyota nations chart shows as 8" 4.10 2 pinion
Old Sep 23, 2007 | 11:44 AM
mt_goat's Avatar
"they"? There is only one pinion gear, its the one that the drive shaft flange bolts to.
Old Sep 23, 2007 | 11:56 AM
I stand corrected -
"yes, the pinion is way in the back, had to look through the bottom. I am positive I counted the pinion"
Old Sep 23, 2007 | 12:01 PM
mt_goat's Avatar
Hmmm... that is odd then. Yes your math is correct.
Old Sep 23, 2007 | 12:30 PM
ok gents - I have concluded a recent study
ALCOHOL HAS SIGNIFICANT EFFECTS ON MY ABILITY TO COUNT.
Katie just got home and I made her count them a couple of times and she got 41 and 10 every time, so apparently I am mildly retarded
Thanks for putting up with me Dale.
Back to my Capt and Coke,
J
PS... I have a matched set of 4.10 front and rear 4 cyl diffs/axle assemblies for sale.
Old Sep 23, 2007 | 12:59 PM
mt_goat's Avatar
LOL, it was probably the coke, try Capt & beer instead. 3/4 shot of Capt Morgan poured directly into the beer We have weak beer here in OK so that's the trick.
Old Sep 23, 2007 | 08:30 PM
thook's Avatar
Try making some homebrew, Dale. Customized potency!
Old Sep 24, 2007 | 03:47 AM
mt_goat's Avatar
Maybe I will...after I run out of things to do on my truck.
Old Sep 24, 2007 | 09:36 AM
GSGALLANT's Avatar
Sounds like you counted the tooth that you punch marked as "1", then you went around the gear and counted the punched tooth again at the end? Glad to hear you figured it out, though. 4.10's sounds better than 3.81's.
Old Sep 24, 2007 | 06:11 PM
Targetnut's Avatar
so tell me,
Did she gripe about the smelly gear lube when you made her stick her face in there?
Old Sep 24, 2007 | 06:20 PM
nope, I got a tough woman - she likes gear oil, just not in her hair, lol
gallant - you are 100% correct
RatOmeter
Oct 22, 2015 03:17 PM
norcal98
Aug 10, 2015 06:20 AM
wolfpackfan33
Aug 2, 2015 03:36 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
