- New(ish) rims!
- Auto-->Manual Tranny Swap?
- Auto Tranny Dying?
- Does The Po Love Your Truck????
- Lift w/bilstein's
- clear lights
- Help!!! White smoke spewwing from my exhaust!
- 2nd gen steering damper...IFS
- Poor Acceleration
- why is my truck hard to start when in cold weather?
- hard in 1st weird in rev. bushing?
- '94 22RE stumbles when cold.
- Amp wire diagram
- Check engine light
- Won't go into gear
- 22RE Spewing Coolant
- Leftover 3VZE gaskets & o-rings; anyone doing a rebuild or partial teardown?
- Awwwwwww Sheeeet Summertime!!!!!
- random T bar question
- oxygen sensor
- carbon smell ?
- Diagnostic Plug, What is there?
- Horrible Herculiner experiance!! Very disapointed.
- shackles or new leaf pack?
- Stock clock wiring
- Gauge install
- 3VZE TOP END+homemade ??Y PIPE?? MOD!!!
- 4.30 to 4.88 31 to 33
- Uninstall aftermarket cd player 94 pickup
- so what are some common problems? 3vze
- intermintent lack of fuel
- interchangable tranny ?
- 3vze head gasket replacement : my turn
- Glasspack muffler
- OFF TOPIC: Need help with wire repair!!!
- Valve Adjustment COLD v HOT
- Idler Arm Identification
- hub problems!
- Boost increase on 2.4TD
- Vacuum line leak??
- bad mileage
- Bilstein 5125 shock valving??
- 4X plug #3 has fouled
- Urban Camo Photos?
- Valve cover gasket bolting order
- FS: 1990 4Runner SR5
- advice on some wheelin' upgrades for 4runner
- white face guages for a 91 pickup
- backfire and no start
- Is my truck eating starters?
- Torn Cv Boots
- any super secret transmission quieter additive?
- blown shocks...upgrade to gas?
- My 89 4runner
- rattle can paint
- 1.50" Wheel Spacers
- Painting
- Quick fix for steering stops?
- Transmission Cooler Install.. With Pics!
- HELP!!! 87 22ret wont idle
- Wont start unless jumped
- LCE header problem..HELP!!
- Creaking Steering
- Rear Window Problem
- Where to buy 22re longblock?
- need help quick(main bearing)
- problems with auto trans
- Fuel Pump / Bracket / Line / Filter Problems!!!
- Sale price advise 91 4runner
- ARGGGG:Broken Zerk
- Parts Catolog
- CV Joints Failing?
- Either oil leak or this things chugging oil
- Home Alignment with pics
- buttons on 1990 auto shifter console What do they do?
- Gear Shift won't release
- 4" lift shock lengths needed....
- Getting plans together summer 4runner project!
- Window rubber... fronts and rear
- New
- 89 pickup IFS parts
- a/c amplifier removal
- Tps Help Quick
- EGR Delete?
- Wanted: leads on 92-95 pick-ups 4sale in Ont.
- Need Pic of ECU Mounting 86 4 Runner
- 22re tps problems
- Re intro - New Toy - couple questions
- Idle Problem
- 22R Starter Problems
- 197k mile touchup
- inslation for under hood of motor
- 1990 4x4 v6 locking hub questions. man vs auto
- Fuel Filter Location :QUICK!:
- Manual trans swap
- Steel Wheel Rust
- Is that an Antenna in the rear window???
- Dual shackles in the rear?
- White LEDs in the Gauge Cluster
- dash pot on 3.0
- '92 4-Runner Shocks
- does anybody have a first gen 4runner 4sale?
- Steering leak, and torsion bars
- BJ lifted 1988 truck
- Front Suspension Noise
- help please with Hard shifting auto tranny, 22re
- Sway Bar Question
- Bronze Idler Arm Bushing Fitment Trouble
- Soft Tops on 1st Gen 4runner
- Runnin rich after Oil Change
- Rear main seal
- Wheel Spacers or not? i got clearance pic.
- Edelbrock IAS Shocks, Please Help!
- question on windows
- "Charge" light keeps coming on
- 1992 pickup problems??
- Help finding resource about hours to rebuild engine
- my quest to get this thing running
- Power Window Problem
- Grinding when trying to start.
- axle spline count
- Can't Find Steering Leak
- odometer stoped
- i'm gonna start slow,
- Vibration FIXED - hallelujah!
- 1993 Toy 4x4 V6 SR5 Truck probs...
- Coolant leak after HG repair - 22RE
- window sticker for model below sr5?
- Transmission question
- 22RE running rich
- Flowmaster 40 series offset IN and OUT
- LCE header causing rich condition?
- speed sensor troubles
- Fixin body damage...
- Aux light connect to positive battery terminal/cable
- Supra to 3vz wiring harness Possibles.
- New TPS: I think I'm in love!
- Front axle locating problem...
- Radio Anti-theft Code
- Is this my water pump leaking?
- list of lift parts. downey style.
- dumb truck. if only i didnt love it. starting problem
- main bearing - thrown rod
- 22r coolant in exhaust (but not from 4 exhaust ports)
- old torsion bars?
- Changing glass in topper/cap
- help...on the side of the road right now
- Overview of my Truck, and the future
- Console In Yipee !!
- 1990 4Runner Long Travel Suspension
- Shocks
- electrical gremlins! help!
- 22re
- Need help quick..
- What is this called?!?
- Solid Brass Idler Arm Bushing Kit!!!!!!!!
- tech book
- tranny input shaft question
- Typical Vac leak locations?
- New exhaugst
- Cleaning my Motor
- Rear speaker removal
- Drive shaft
- 4runner won't idle/ run correctly
- Everything is new, so why doesnt my a/c work?
- trouble after water crossing
- Front diff locker on IFS?
- speed sensor 92 4runner
- Paint job and rust removing-- finished.(pics) ..next project started :)
- Seat belt buzzer
- SAS Question
- Deckplate Question
- lights mounted below windshield
- turbo questions
- Universal er'direct fit...
- width / lenght of OEM hood
- Newb Question on Sunroof Repair
- distributor selection problem
- Swapping seats
- 4runner cb radio antenna
- easy way to remove #1 spark plug anyone??
- A few questions regarding brakes, bleeding the master cylinder and rear diff
- Buzz in Airbox
- Starting problems, new starter
- Timing Chain Issues
- 22R overheats with thermostat in
- Tune Up Time!
- Colo Area Folks 3.4 on CL
- Cat install
- 4runner not starting
- How is this part removed and installed????
- need to replace HG (+ possible valve job) but am worried about bottom half...
- Manual Hubs
- shifter washers
- Not running right after valve cover swap
- Here is my updated Truck.
- Does Toyota use any 9mm nuts or bolts on the 2 gen 4Runner?
- Shifter Stuck in Gear!!!!
- transmission/t-case manuals
- wheel spacers
- how to disable the seat belt alarm?
- 07 Hot-rama(56K be Gone)
- seat belt retractors?
- Quick Help!
- O2 Sensor Flange Welded!!
- Took off my 4runner top today! I'm lovin' it?
- I got rear-ended! my poor baby!
- 22re build-up
- How do you test Vane Air Flow Meter, or...
- 3.0 questions
- Power Steering and Tachometer
- Digital water temp gauge install?
- when installing an AAL how do you get the center pin out?
- Waka Waka Waka From Rear Diff
- Gears from Taco to 4rnr...will they fit?
- Good bracket lift mod
- 1988 22RE to be scrapped
- Tranny/Transfercase problems
- Rear window wont go down(searched)
- Belts Needed for E-Fan Install
- My 88 4runner ***pics*** 56k beware
- FIPG Online?
- O2 sensor differences?
- Manual Hub Rebuild(grease)
- brakes...can't be too good.
- digital dash problem
- 2nd Gens doing the 50N recall POLL!
- rear locker
- 4crawler's bikini top
- Rear window on 1st gen
- Mounting point for aux. Trans cooler?
- Have a Canback? Have a question
- Doors off?
- AC recharging question.
- 88/89 Speed Sensor - # pules?
- speed sensor
- V6 Problems
- Auto trans help please
- Rear Springs for My 88
- need to pass emissions!
- Pics of my 1988 Toyota Driveable Project
- 88 truck underpowered (and other issues)
- Lug Patterns Between Generations
- T100 brakes on Pickup/4runner?
- 1986 4RUNNER skid plate.
- yet more brake problems PO was a POS
- Selling my truck in the classifieds
- overheating 3.0
