bad mileage
Old May 10, 2007 | 02:48 PM
andrew241's Avatar
bad mileage
Hey folk, new posting here. You ugy got tons of good info out there.
So here is what I got, 94 xtra cab with a 3.0, the mileage went way down from last year and it has been running kinda rough especially at idle. I took the plugs out and they had normal wear on them and all that but I cleaned them anyway. Occasionally I get a miss during running as well. What do you guys think?
Old May 10, 2007 | 02:52 PM
notanymore's Avatar
o2 sensor? im not sure if i would cause it to miss and run rough at idle but its something that proally needs to be changed
Old May 10, 2007 | 02:54 PM
91TPU's Avatar
take a look at your air filter, clean your MAF..
i wouldnt have pulled the plugs and cleaned em either, you shoulda just replaced with new...infact, with what you said i would prolly do a full tune up, sounds like its about that time...
Old May 10, 2007 | 02:58 PM
ChickenLover's Avatar
Yeah, it's probably time for a tune up.
-Plugs, wires, cap & rotor
-Air filter
-o2 sensor
-Fuel filter
-PCV valve
Just how bad is your gas mileage?
Old May 10, 2007 | 03:31 PM
andrew241's Avatar
-Air filter
-o2 sensor
-Fuel filter
-PCV valve
Well last time I measured it I am at about 14 onthe highway less in the city.
The air filter is less than a year old, 02 sensor well I dunno lol, fuel filter is 3 months old, pcv valve the same.
I don't ilke the wires on my truck either, they are these little tiny flimsy looking things. They have performance sets out there but I have only been able to find the real expensive ones.
What plugs you guys running?
Old May 10, 2007 | 04:24 PM
andrew241's Avatar
-Air filter
-o2 sensor
-Fuel filter
-PCV valve
I am getting about 14 highway and less in the city, the fuel filter is less than a year, air filter less than a year along with the pcv. The stock wires are wimpy but they are expensive. What plugs and wires you guys running?
Old May 10, 2007 | 05:57 PM
andrew241's Avatar
-Plugs, wires, cap & rotor - less than 2 yrs
-Air filter - less than 1 yr
-o2 sensor - dunno lol
-Fuel filter - less than 2 yrs
-PCV valve - less than 1 yr
I am getting about 14 highway and less in the city. I use it as a daily driver right now too, I have manual hubs so they stay unlocked.
Old May 10, 2007 | 06:00 PM
curtiswyant's Avatar
Tune-up time! I'd also make sure you're calculating the mileage accurately, and check your alignment/tire pressure etc.
Old May 10, 2007 | 06:06 PM
andrew241's Avatar
yea tires are good, alignment well shuold be good lol
Old May 10, 2007 | 06:39 PM
91TPU's Avatar
hmm i would take a look at your distro cap and rotor, my contacts were really worn down, causes stuttering, poor mileage, and sometimes a miss...
Old May 10, 2007 | 06:57 PM
keithguts's Avatar
I had the same problem, did everything with no luck. Turned out that the miss would come and go. One day the miss came, and never went away. Turned out to be a bad exhust valve.
Old May 10, 2007 | 09:13 PM
andrew241's Avatar
I don't wanna hear that lol. Well I will check the cap and rotor along with some other stuff this weekend. Thanks guys. I am also going to do a few other things a have found on here as well. I like this place so I am putting up and tent and staying lol
Old May 11, 2007 | 02:04 AM
Kutter's Avatar
x2 burned valve
Start saving your money now and do a 3.4 swap when the 3.0 dies
Old May 11, 2007 | 02:07 AM
Emms4runner's Avatar
-Air filter
-o2 sensor
-Fuel filter
-PCV valve
What is this PCV valve?
Old May 11, 2007 | 08:38 AM
91TPU's Avatar
positive crankcase ventilation...its on the left side of the intake plenum on the 3.0, your gonna need a flashlight tho as its hard to see/get at...
Old May 11, 2007 | 12:37 PM
andrew241's Avatar
Originally Posted by Kutter
x2 burned valve
NO I don't wanna hear anyhting like that lol. How much is the 3.4 anyway?
Old May 11, 2007 | 12:41 PM
TNRabbit's Avatar
Use NGK or Denso plugs.
Did anything unusual happen when your mileage went down? Have you made any changes to the truck? New tires? Steering recall? Was it sudden or over a period of time? More questions need to be asked/answered before everyone has you throw money at it.
Old May 11, 2007 | 12:48 PM
dijlop's Avatar
anywhere from 2000 to 3000 grand depending on your mechanic skill level and your ability to find cheap stuff.
Old May 11, 2007 | 01:11 PM
andrew241's Avatar
Ohh i can do it but dang thata some $$$ As for the mileage I has been a gradual thing, it has gotten worse the longer I have had the truck.
Old May 11, 2007 | 02:24 PM
TNRabbit's Avatar
By the time you get done with a 3.4 mod you could potentially have $5k in it (some have)...just FYI. Like dijlop said, it depends on your mechanic skills & ability to find stuff on the cheap.
