Tps Help Quick
Old May 8, 2007 | 06:51 PM
gametom's Avatar
Tps Help Quick
which connector and pins do i jumper for the "timing test jumper" mentioned in this http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
i have a 22re in a 91 runner
thanks
Old May 8, 2007 | 07:16 PM
thook's Avatar
I assume you're referring to this step?
"To check whether the adjustment was successful start the engine and insert the timing test jumper, if the idle speed decreases audibly it is working normally"
Look around your ignition coil...somewhere possibly between there and the AFM on the fender well. There should be some dummy plugs. Two yellow ones and two green ones...plastic. Of the green, one will have two female terminals. Jump those with a paper clip.
Yours may be different, but that's how it is on my '86. Figure it wouldn't hurt to throw it out as a possibility.
Old May 8, 2007 | 07:25 PM
Itoyota's Avatar
nah, .. not if he's got my Electronic setup. Next to the main relay box near the intake. There should be a check connecter there (gray). If you look on your hood you might get lucky and get two arrows conveniently pointing to them. if you still need the help, i can go pop the hood.
Old May 8, 2007 | 07:28 PM
ewong's Avatar
91 has a later style test plug..
The test connector is attached to the fuse box. It has a little flip off lid...
Jumper T and E1.
Positions are marked on the flip off lid..
Old May 8, 2007 | 07:38 PM
gametom's Avatar
Jumper T and E1.
Thank You
Old May 9, 2007 | 07:02 AM
thook's Avatar
Jumper T and E1.
I thought it might, but since it was 22re...
Old May 9, 2007 | 10:03 PM
karshin's Avatar
http://www.4crawler.com/4x4/CheapTri...CheckConnector
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
zytra
Jan 24, 2019 03:16 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
charlie_fong
Sep 27, 2015 10:06 PM
