22re tps problems
Old May 8, 2007 | 02:03 PM
907yota's Avatar
22re tps problems
hey guys n girls,
I just put a fresh new 22re engine in my 93' p/u. I had my throttlebody and intake cleaned and the shop i took it to removed th throttle position sensor and put it back on without adjusting it back to specs , causing the engine to surge between 1500 and 3500 RPM, anybody have any idea what the factory specs are? and how to remedy it thanks
Old May 8, 2007 | 03:41 PM
zozoka's Avatar
Hello
Had the same problem with the TPS sensor in V6 3.0
https://www.yotatech.com/forums/f116/gap-between-1800-2300-rpm-tps-problem-109638/
I adjusted to the specifications , following 4crawler description, now everything is fine.
You find here :
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Zoli
Old May 8, 2007 | 04:00 PM
slacker's Avatar
yikes .. I guess your not taking it back ?
http://personal.utulsa.edu/~nathan-buchanan/93fsm/ is the service manual on line .. check out the specs there , and have fun .
Old May 8, 2007 | 04:20 PM
907yota's Avatar
Right on, i'll try it out, big mahalos fo da info
smthwsn357
May 1, 2024 07:28 AM
jbv808
Aug 6, 2021 04:47 PM
Sleaker
Aug 26, 2020 06:03 AM
steve miller
Oct 10, 2015 01:40 AM
ryerye13
Jul 14, 2015 08:27 AM
