SAS Question
Old May 4, 2007 | 01:15 PM
EvLTwiN's Avatar
SAS Question
i see these kits for doing the sas which are intended for the toyota front axles but has anyone tried using this kit with any other axles such as chevy 1/2 3/4 or 1 tons? does the width work out ok or do you have to set the springs a little farther apart?
Old May 4, 2007 | 01:20 PM
Kaleb's Avatar
check out sky-manufacturing.com
Old May 4, 2007 | 01:24 PM
waskillywabbit's Avatar
Using the kit for a non Toyota axle defeats the purpose.
Too many things would not work such as the knuckle rebuild, the steering arms, diff armor, etc
Im in Tuscaloosa.
Old May 4, 2007 | 01:33 PM
AxleIke's Avatar
Sky has a kit for using other axles, as was previously stated.
Wabbit also has a good point.
The Sky kit, i believe, is just the hanger and the offset shackle.
Old May 4, 2007 | 01:36 PM
EvLTwiN's Avatar
yeah i just checked out the sky kit and all it is is an offset to accomodate the full widths, which is what i want. wabbit do you have a full width kit?
and a side note, wabbit, are you familiar with grey rock orv in mt olive?
Old May 4, 2007 | 01:49 PM
Smile
Im an all Toy junky for now so no full width kits.
I lived in Gardendale for 2 years.
Old May 4, 2007 | 01:54 PM
tc's Avatar
tc
If you're gonna do anything other than toyota axles, it doesn't make much sense to put anything 1/2 ton under there - they're weaker than the Toyota axles.
To do it right, when you go full width, you need full floating strong 3/4 ton or 1 ton axles IMHO. So you're looking at D60, 14 bolt FF, or custom (like diamond axle)
Flying91
45
Apr 11, 2024 04:39 PM
Shagool22
Aug 14, 2015 12:24 AM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
