Transmission Noise
Old May 12, 2007 | 04:40 PM
95Rnr's Avatar
Transmission Noise
I have a 95 4Runner with a 3in OME lift. Recently, I have been hearing a vibrating/grinding sound from the transmission. it usually occurs between 30 and 40 mph or it atleast intensifies. I can kind of hear it at higher speeds but it is not as loud. There has been no change in shifting or acceleration and the tranny fluid is full. What could be causing this noise?
Old May 13, 2007 | 07:41 AM
AH64ID's Avatar
Probably your rear u-joint talk to you because of the lift. You may need to get adj upper links to point the pinion at the transfer case a little more. You may also need to upgrade to a CV style joint on the trans side, I had to do that on my 95 runner.
Old May 13, 2007 | 08:54 PM
95Rnr's Avatar
Would a panhard rod drop bracket help with the angle of the driveshaft?
Old May 14, 2007 | 08:27 AM
AH64ID's Avatar
Do you not have one? It wont help the angle you need, but it will get your axle back where it should be, right now its probably offset and slightly crabbed.
Old May 16, 2007 | 07:08 AM
Designsbyme's Avatar
I have this same problem. Started about a month ago. No lift. 95 4Runner auto. Would like to see if this thread comes up with more info.
Old May 16, 2007 | 07:49 AM
rtchrg440's Avatar
Check out this thread:
https://www.yotatech.com/forums/show...line+vibration
jashoeuh
Nov 18, 2024 08:08 AM
crammit442
7
Nov 29, 2017 12:30 PM
mskalmus
May 28, 2017 07:51 AM
mengquis
Jul 13, 2015 10:39 AM
Poncho0206
Jul 10, 2015 06:21 PM
