Valve Adjustment COLD v HOT
Old May 10, 2007 | 08:33 PM
Rebel's Avatar
Why is it that when people adjust the valves cold, the clearance gets larger as it warms up? I've seen numerous posts about adjusting the 22r's valves to .007 intake and .011 exhaust and when they are checked hot, they become .008 and .012 It makes no sense to me lol. As metal heats it expands and the tolerances should be tighter.....
Old May 11, 2007 | 05:12 AM
Rebel's Avatar
anyone??
Old May 11, 2007 | 05:22 AM
4Hummer's Avatar
Beats me why. We need someone with a degree in metallurgy.
I always set them Cold .007 and .011,
Problem setting them hot is
A: It burns.
B: by the time you get to the last Valve the engine is much cooler that when you did the first valve.
Old May 11, 2007 | 05:24 AM
JEDI87's Avatar
I jusr checked with my machinest and he said to adjust them to 7 &11 cold.
Old May 11, 2007 | 05:26 AM
TNRabbit's Avatar
You just throw a blow torch on them for a few seconds & they are hot again!!
Old May 11, 2007 | 05:50 AM
MMA_Alex's Avatar
i've had bad luck doing em cold. best i've found is .007, and .011 hot, and trust me ive adjusted em atleast a half dozen times in the year ive owned the truck
Old May 11, 2007 | 06:02 AM
thook's Avatar
Mmmm....petro flambe. I always keep a set of Craftsman skewer's handy for just such occasions...metric, of course.
Old May 31, 2007 | 06:26 AM
DaveInDenver's Avatar
Good question. I've always done 0.008/0.012 hot on the stock engine. I put an Engnbldr cam in my engine and the numbers Ted me are 0.007/0.011. I did them to these numbers hot and they will pass the feeler with resistance and the next size up won't go (for example, 0.007 is snug, 0.008 won't go). I have no idea if that is right, but that's what I did.
bigjstang
Jun 2, 2025 03:56 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
calderp
Jul 27, 2015 09:58 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
razorman8669
Jul 12, 2015 12:13 PM
