easy way to remove #1 spark plug anyone??
Old May 3, 2007 | 09:18 PM
weakyota91's Avatar
any one who has even ever looked at there spark plugs know that number five cylinder spark plug is a PIA to get to. (thats passenger side closest to firewall) anyone have a special trick to getting to that. easiest way i have found is swivel and lots of extension. let me know if u know different thanks
Old May 3, 2007 | 09:23 PM
KTMR1der03's Avatar
Its been a while for me, but swivel extension was the only way I could do it, verrrry hard to see in there. Just guide the socket with your hands and poke at it until its around the plug. Real pain.
Old May 3, 2007 | 11:38 PM
SpeedyJ's Avatar
Yeah it sucks. I think I eventually came up from the bottom on my friends 4Runner with a swivel and two extensions on either end of it. Spin slow and easy until you feel it catch nicely, aka careful not to crossthread it and strip the threads.
Old May 3, 2007 | 11:49 PM
thook's Avatar
Spend some money....get a bionic arm. Titanium is the rage.
Old May 3, 2007 | 11:54 PM
ChickenLover's Avatar
Remove your charcoal cannister.. Put a couple of extensions together and you'll have a straight shot at it.
Old May 3, 2007 | 11:56 PM
thook's Avatar
And hold your mouth like Hillary.
Old May 4, 2007 | 07:12 AM
Marc's Avatar
That's the secret.
Old May 4, 2007 | 07:18 AM
GM TURBO's Avatar
Try sticking your tongue in the right corner of your mouth while using your left hand to turn the socket...
Are you pulling it out - or putting it back in?
I actually used a shorter extension and a ratchet - broke it loose and then spun it off by hand. Putting it back in - insert the spark plug in the socket (mine has a rubber o-ring to hold plugs in place) and thread in by hand. Only using the ratchet/extension for the last few turns.
Old May 4, 2007 | 07:26 AM
Bumpin' Yota's Avatar
gm turbo nailed it.
I use the sparkplug socket, a short exension, and a 3/8" to 1/2" adapter. The get a 1/2" ratchet and bust it loose, remove ratchet and unscrew it the rest of the way by hand. Installation is reverse order.
And yes it will all be under the vacuum line mess...
Doing it this way a plug change takes 20 to 30 minutes total. Oh and occasionally swear, even if you have nothing to swear about, it apeases the busted knuckle gods....lol
Old May 4, 2007 | 11:48 AM
thook's Avatar
That's the way I've come to do it, too. Along with a few grunts for effect.
BTW, I have it on good authority bleeding on your motor is a sacred act.
Old May 4, 2007 | 11:58 AM
hosh's Avatar
Old May 4, 2007 | 12:13 PM
thook's Avatar
Eggslinger
Jun 8, 2019 03:32 PM
raptor510
Feb 17, 2017 07:11 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
cars-guy
Jul 11, 2015 07:51 PM
88runnergomas
Jul 9, 2015 01:12 PM
