How is this part removed and installed????
Old May 3, 2007 | 04:14 PM
swerks's Avatar
Question How is this part removed and installed????
any help appreciated
Old May 3, 2007 | 04:29 PM
leebee's Avatar
you might want to pick the wabbits brain, he has 2 1st gens and should be able to get you going.
lee
Old May 3, 2007 | 06:11 PM
swerks's Avatar
I posted up on wabbits forum as well, any one have a pic of truck without this part attached ? It might help
Old May 3, 2007 | 06:15 PM
80W90's Avatar
they have plastic nubs that snap into plastic holes.
the nubs usally break off. and you are left trying to find one that isnt broke. unless you are painting it, there is no reason to take it off.
well maybe if there is a hornets nest in there, i guess.
Old May 4, 2007 | 02:19 AM
swerks's Avatar
Old May 4, 2007 | 03:22 AM
SEAIRESCUE's Avatar
If I remember correctly, you push them up to start the removal process. There may be a screw on the inside of the cab that must be removed. Plastic plug or "dot" with adhesive is lifted to access the screw. I have mine removed from a 88 x-cab and that was a year ago. I'll check tonight to be sure.
Old May 4, 2007 | 04:51 AM
waskillywabbit's Avatar
Smile
What he said.
New clips can be purchased at the dealer.
Old May 4, 2007 | 12:58 PM
swerks's Avatar
so do you push up or down or pry from the sides ? any body have a part# for the new clips ?????
Old May 4, 2007 | 01:05 PM
deserttoy84's Avatar
what i did was sldie em up then i kinda had to bend the piece to finish slidign it off. I ended up breaking a clip because their old. anyone know the purpose of having vents there?
Old May 4, 2007 | 01:28 PM
ewong's Avatar
Air extraction.
All cars have it.
Some hide it better than others.
On the trucks I think its hidden by the bed?
There is also a hole up high thats REAL convenient for running a CB antenna cable...
Old May 4, 2007 | 06:10 PM
swerks's Avatar
any more input Please!
Old May 4, 2007 | 06:31 PM
DeathCougar's Avatar
Wabbit and 80W90 hit it right on the head. You just gotta snap them off, and the clips WILL break. Then just get the clips out, and get new clips from the dealer. There is really no other way to remove them. They use opposing slots, so there really isn't any way to slide that piece out.
Old May 4, 2007 | 07:13 PM
malinjj's Avatar
You can use the tool for door panel removal, looks like a wide head screwdriver with a v notch in the middle. It also has a slide bend in it. I just took mine off the truck I'm parting out just to see what was behind it. If you need new ones I have them and the little plastic thingys to hold them in place. LOL...
Old May 5, 2007 | 05:36 AM
shiftless89's Avatar
It takes 2 of part number 62955-91c01
and 8 of part number 62955-89101
now this may be for both sides, the EPC sometimes list quantity for 1 side, sometimes both
Old May 5, 2007 | 05:38 AM
Originally Posted by ewong
Air extraction.
All cars have it.
also keeps pressure from building up from extreme summer heat as well as when you close the door it releases the air pressure from building up.
I remember seeing older cars with there windows blown out from hot air build up in the summer. this helps prevent that
Old May 5, 2007 | 05:54 AM
ewong's Avatar
Yup..
I vaguely recall that you use a door panel tool to get the two BOTTOM ones popped and the slide it UP and also to one side. Hopefullyhe clips bust and not the panel
Old May 5, 2007 | 06:06 AM
swerks's Avatar
thank you every one!
bigjstang
Jun 2, 2025 03:56 PM
coryc85
Sep 9, 2015 06:24 AM
ptb12
Jul 5, 2015 01:49 PM
Vargntucson
Jul 4, 2015 12:15 PM
