White LEDs in the Gauge Cluster
Old May 8, 2007 | 04:27 AM
cbrsport17's Avatar
I had to get a bug out of my gauge cluster, it was in there for the past 6 months, and i was getting tired of looking at it, but while i had the cluster out, i decided to take out those green covered bulbs, and i replaced them with white leds, not excellent lighting, but better than that faded green...let me know what you think...
Old May 8, 2007 | 04:52 AM
95ToyotaPU007's Avatar
That looks nice. How did you get to the bulbs for the temperature control cluster? mine has been out for a month now.
Old May 8, 2007 | 05:06 AM
amgraham's Avatar
The temp control just pops out with a little screwdriver and the bulb is behind there.
Looks pretty good man. Too bad they don't spread the light out more though but I like the brightness. Where did you get leds that fit in there? Last time I had my cluster out I converted mine to all red bulbs and it turned out like this:
[IMG][/IMG]
Old May 8, 2007 | 05:27 AM
cbrsport17's Avatar
i got the bulbs out here at an auto parts store called Autobacs, LEDs are real big here in okinawa, its crazy. i wish the light was more spread out, but i like your red, it looks pretty cool
[IMG][/IMG]
Old May 8, 2007 | 05:51 AM
RyanJ989's Avatar
I assume it's 12V LEDs, but what mA? Did they go in pretty easy?
Old May 8, 2007 | 06:19 AM
cbrsport17's Avatar
just your normal everyday 194, of course in LED tho...
Old May 8, 2007 | 07:59 AM
stock87's Avatar
Did they look like normal LEDs, or were they the kind that are supposed to diffuse the light better? I've been thinking about doing the same thing and the guys at http://superbrightleds.com have some that are supposed to diffuse the light better.
Old May 8, 2007 | 01:52 PM
cbrsport17's Avatar
i think they were just normal LEDs, it was all in japanese writing so i am not too sure on what exact kind they were, but i know before i hooked them up, they were bright as hell turned on....
Old May 8, 2007 | 02:03 PM
notanymore's Avatar
when i had mine out i put blues in there instead of the green ones that were in there, ill try to get some pics of it,they arnt that bright but still kinda cool, it matches my cd player and sirus so it works
Old May 8, 2007 | 02:08 PM
yotasavg's Avatar
ooooo! i like this project. is it easy to get the gauge cluster out?
Old May 8, 2007 | 02:55 PM
shoes138's Avatar
yea there really easy to take out. All it is, is bolt screws holding it on to the dashboard and all the wiring n cable.
Old May 8, 2007 | 03:39 PM
cbrsport17's Avatar
sounds cool, i would like to see...
Old May 8, 2007 | 03:40 PM
cbrsport17's Avatar
it took me about 45 mins for the whole project, really easy
Old May 9, 2007 | 09:40 AM
97Limited's Avatar
I've done my 3rd gen, with Blue LED's
And I even use these same LED's but White in my Corners, License plate, in my PIAA's
But the LED's that I used are even brighter then the regular 194 bulbs that i replaced>
The side pointing LED's spread the light>>
Old May 9, 2007 | 11:45 AM
aviator's Avatar
97 where did you get your leds?
what size/code are they?
thanks aviator
Old May 9, 2007 | 01:30 PM
97Limited's Avatar
thanks aviator
Yeah I used the 194 bulbs (WLED-x5 LED Wedge Base Bulbs)
Here's the Link> http://www.superbrightleds.com/mini-wedge.html
Old May 9, 2007 | 02:21 PM
Seans4Runner's Avatar
I used to do alot of neon lighting, then switched to led and cold cathode tubes. Check out www.oznium.com I've shopped with Phil for quite a while and theres a trick or two to learn about leds. I noticed that you've got dark spots cause your leds are a concentrated light source. If you take a file and carefully file the ends of them down, it dispurses (sp?) the light better.
Check these out: http://www.oznium.com/prewired-superflux
Old May 9, 2007 | 02:49 PM
cbrsport17's Avatar
so you are saying just file the tip down and it should dispurse the light better? i might have to try that and see if it makes a difference in my dash...
Old May 9, 2007 | 06:11 PM
Pretty much. Be careful you dont file down too far cause you'll hit the diode. Some work better than others, but it should deffinatly help and getting rid of super bright "spots"
Old May 9, 2007 | 06:17 PM
Avsfreak1234's Avatar
great thread! Iv been wanting to do blue led's in my dash for a while to match my CD player and my radar detector
