3VZE TOP END+homemade ??Y PIPE?? MOD!!!
Old 05-11-2007, 09:15 AM
Chief_Yota's Avatar
alright well here it is i guess ill let pics talk for me,and the ??y pipe?? mod is not yet finished so im gonna go threw this with yall.
Old 05-11-2007, 09:18 AM
Chief_Yota's Avatar
be carefull with the injectors cause i broke one trying to clean it up ,well it only cost me 112 can dollars for a rebuild one and i broke a damn bolt inside my head cover right side so be carefull when taking those off!!
Old 05-11-2007, 09:21 AM
Chief_Yota's Avatar
Old 05-11-2007, 09:24 AM
Chief_Yota's Avatar
new water pump on left old one on the right
Old 05-11-2007, 09:26 AM
Chief_Yota's Avatar
those are the sensors ,they seems clean to me ,so im putting them back in,i just left them in some CLR for the night.
Old 05-11-2007, 09:28 AM
Chief_Yota's Avatar
heres the cams:
Old 05-11-2007, 09:37 AM
Chief_Yota's Avatar
Old 05-11-2007, 09:42 AM
Chief_Yota's Avatar
this is my stuff out ;
Old 05-11-2007, 09:45 AM
Chief_Yota's Avatar
the oil cooler was completly cloged!!! in the water passage,wit some kinda sand,anyway im glad i took it out,there was no water going there at all!!!
Old 05-11-2007, 09:48 AM
Chief_Yota's Avatar
the injectors pretty clean already cause i always use high octane fuel and fuel cleaner every oil change,well i guess.
heres my new water pump on;
Old 05-11-2007, 09:51 AM
Chief_Yota's Avatar
i heard alot of stuff about people saying i use carb cleaner to clean the cylinders but theres only one thing THAT REALLY WORKS;
EASYOFF OVEN CLEANER ,thats the bomb;
Old 05-11-2007, 09:52 AM
chimmike's Avatar
Good God, from the depth of those valve reliefs, you'd almost think this was a 12:1+ compression motor!
Chief_Yota's Avatar
thats clean ,and i just ad to spray and wait 1 hour and wipe,no scrubbing watsever,
Old 05-11-2007, 09:54 AM
Chief_Yota's Avatar
hell yea i love my easyoff stuff ,if i could id sleep wit it
Old 05-11-2007, 09:57 AM
Chief_Yota's Avatar
yea i know the cyinders looks good thats why im only doing some top end ish. SO heres the problems; hg was blown up left side from front of car,numb 6 valve(intake) was BROKEN??!!! unbeleivable i sended my heads to clean and change numb 6 intake valve and all the other crap i cant do.
chimmike's Avatar
I don't think I'd use oven cleaner. That's not going to leave any sort of a lubrication on the surface, so you really need to run assembly lube on the cylinders before throwing everything on and cranking it up again.
Old 05-11-2007, 10:02 AM
TNRabbit's Avatar
I was just thinking the same thing. You might want to change your oil now, as I'm certain some of it ran past the rings into the crankcase. Looks good, though! I applied STP oil treatment liberally to my pistons, rings, cylinder walls, crank/bearings, oil pump, etc.
What else are you planning? How many miles on your engine? Have you double checked the idler pulleys for wear? I had to replace both mine. I'd SERIOUSLY consider a new oil pump while you've got it apart.
Great pics; you just need to get better at focusing on the thing you're taking a picture of!
Old 05-11-2007, 10:04 AM
Chief_Yota's Avatar
the awser to that is my other little friend : LAQUE THINNER ;powerfull remover
Old 05-11-2007, 10:09 AM
Chief_Yota's Avatar
alright so ,im planing to do a Y pipe MOD ill call it the ;CHIEF PIPE MOD,anyway sorry about the pics focus i gotta crappy camera,as for the pulleys ive checked them and lube them with this ON THE LEFT ,and its rolling clean and perfect!!
Old 05-11-2007, 10:12 AM
Chief_Yota's Avatar
i bought myself a micro ajusting torque wrench for putting things back correctly. cause that old one just aint that precise and it only goes to 60l-ft
Quick Reply: 3VZE TOP END+homemade ??Y PIPE?? MOD!!!
