white face guages for a 91 pickup
Old May 10, 2007 | 10:57 AM
weakyota91's Avatar
i have searched and looked all over ebay and cant find white guages for my 91 toyota pickup sr5 with a tach. Will the one for 4 runners fit. Tach and spedo in middle. oil pressure in top left, temp lower left, batterie in upper right and gas below that. I havnt even seen picks other other than in 4 runners. HELP PLEASE
Old May 10, 2007 | 11:26 AM
Elton's Avatar
here you go
http://cgi.ebay.com/ebaymotors/1989-...QQcmdZViewItem
http://cgi.ebay.com/ebaymotors/1990-...QQcmdZViewItem
Old May 10, 2007 | 11:36 AM
Jay351's Avatar
Gas guage, temp guage, oil guage and battery guage are mixed up..
Old May 10, 2007 | 11:45 AM
weakyota91's Avatar
exactly jay351 I noticed that also but forgot to mention it. thanks tho elton i seen that same thread that lead me to ebay. oh well mabye i will just tear it apart fix my low fuel bulb that has been burned out for 4 years and stick blue bulbs in there. anyone know for sure how many i thinks its 3 altogether
Old May 10, 2007 | 01:53 PM
Itoyota's Avatar
yeah, and when you tear em apart ... im not sure you can find blue bulbs that size... correct me if i am wrong, but the bulb is about as big as my wristwatch adjustment knob ... and it comes clear, and with a rubber green condom ... sooo. Let me know how you plan getting around that ... ill follow in your footsteps.
Old May 10, 2007 | 04:40 PM
weakyota91's Avatar
ITOYOTA: i just finished replacing they instrument cluster bulbs with blue ones. I seen the little ones that u were refering to. On my 91 pickup those little ones were just for the seat belt, 4wd, engine lite and brake lite and highbeam all down at bottom and those have there own individual clear bulb but the plastic the bulb lights up was colored itself so i left all those clear (example 4x4 is green, CEL is orange, seatbelt and brake are red) I only replaced the 3 bigger (194 bulbs) those were the 3 on myne that had the little blue condoms on. I will see tonite what it looks like when it gets dark
Old May 10, 2007 | 04:45 PM
Elton's Avatar
there not one piece you put them where there suppose to go to prove my point here you go https://www.yotatech.com/forums/f126/indiglo-gauges-1995-4runner-75768/
Old May 10, 2007 | 04:54 PM
weakyota91's Avatar
oh u can switch them around to match the pickup. so when i order them for my truck i will just have to order them as if they were for a 91 4-runner. am i correct?
Old May 10, 2007 | 05:02 PM
Elton's Avatar
yep the 4runners are the same
Old May 10, 2007 | 08:08 PM
cbrsport17's Avatar
three normal sized 194s, and then 2 smaller ones, one on each side, i just switched my bulbs out in my Surf....
Old May 10, 2007 | 09:07 PM
JEDI87's Avatar
Streetbeat customs had them when I looked for mine.
Old May 18, 2007 | 09:34 AM
weakyota91's Avatar
OOPS i guess i missed a couple small bulbs. my four guages in each corner are still white but speedo and tach are blue
Old May 18, 2007 | 01:07 PM
Itoyota's Avatar
how do you get the dash apart... have any pics?
Old May 18, 2007 | 01:12 PM
Elton's Avatar
enjoy https://www.yotatech.com/forums/showthread.php?t=75768
Old Jul 19, 2007 | 02:00 PM
Belize Off Road Team's Avatar
how many bulbs are behind that gauge cluster, i want to replace all of the with LEDs and i need to know how many bulbs there are, (4x4, battery, brae, seatbelt, REVs speed, oil, fuel, temp, battery gauge, high beam, etc etc, how many all together?)
Old Jul 19, 2007 | 02:05 PM
Knuckles's Avatar
offtopic but,
elton, youve become the master of searching!
Old Jul 19, 2007 | 06:37 PM
95RunnerSR5's Avatar
using different colored LED's with a spread pattern came up in a similar thread a while back...
http://www.superbrightleds.com/cgi-b...gi?product=CAR
steve miller
Oct 10, 2015 01:40 AM
Kluch8651
Jul 9, 2015 10:39 AM
raiderhawks00
Jul 8, 2015 06:23 PM
