- 3vze swap, idles fine, but no throttle
- Usa standar gears??
- 86 runner leaking auto trans
- IFS Carrier Drive Shaft Bearings
- Replacing my clutch. I have a couple of questions, with pics.
- Power loss when a/c on? help
- Toyota 3VZE woes
- 3VZE valve check/adjust
- Grille ony 1986 Toyota pickup sr5 xtra cab
- sr5 gauge cluster
- testing cold start circuit, NOT injector
- 4Runner dies while Driving
- 89 4runner ebay black projector housings and 10000k hids( lots o pics)
- new 2nd Gen Runner owner
- Where do I hook up the fuel pressure gauge..
- clutch pedal shake
- Starter issue. doing nothing when key is turned
- Pick up coil??
- regular cab owner, how do you carry your rifles
- Steam/smoke from vents
- leaf springs in 4 runners
- Did the e fan swap
- cel crazy!
- Exhaust work...
- 2in lift is on. Thanks to all those who answered my questions!
- Parking light hell
- Its Dead, Engine grenaded
- 89 4runner low fuel pressure at cold start
- code 71...need to smog soon, help!
- remove crankshaft pulley (not the bolt)
- ac compressor rebuild kit and leaf mounts
- AC not cold, compressor working...
- My horn only works sporadically! Help!
- How to set my clock??
- brake fluid leak between master cylinder and reservoir
- 1986 yota wiring
- My new $700 Toyota Pickup!!!
- Afm help please
- problems with "oe brand" ball joints
- Shock install help!!!!!
- Blowing white smoke, not the Head gasket??
- Truck loses all power until shut off, but does fine with above half tank
- Clunking when pressing the gas while driving?????
- 1994 toyota 4runner 3.0L overheating?
- The GF rolled my Runner!
- 91' Yota truck blowing a fuse... (Dies)
- Lifted truck, now brakes suck
- 90 4 runner starting to run hot
- toyota fuel filter replacement-HELP
- I have a miss
- Igniter coil resistance test
- 22ret fuel mixture adjustment
- 1988 toyota, revs wierd.
- Front differential help
- Non ADD source on a 91 v6?
- Starting problems when warm.
- 1-4 shift controller?>???
- 1993 toyota rusted front end repair video before and after
- A/C Quits when hot
- Toyota Automotive Technical Training Series
- Idle surging... blown head gasket?
- 4x4 transfer case not engaging
- Need help identifying a part on my 87 pickup
- 86 pickup Bilstein shocks on 91 pickup
- got me a yota
- 92 pickup 3.0 timing problems
- Help on Reassembly After Rebuild
- Urgent help needed. Code 31. Starts then dies.
- Turbo Runner
- 89 toyota pickup color coded vacuum lines
- Am I bein too overly worried?
- Ac line indentification help
- Reproduction Fuse Box Decal
- rediculous coolant leak...
- 87 yota p/u trans leak
- Speedometer 94 SR5 PU 4x4
- Desperately need a NEW 22RE Head!!! PLEASE HELP!!!
- Transfer case mount?
- Where the heck does this bolt go? (pics inside)
- 88 3vze idle high
- wheel spacer close call
- Brass idler bushings from SDORI
- 22re not starting
- My Camo Paint-job... *pics*
- problems after doing headgasket
- 3days and $20.. hello new toy
- What Are These Electrical Devices?: '88 4runner
- EGR completely removed
- rusting bed
- 3vze running hot mystery
- Throttle Body Gasket needed?
- rad lower hose mod
- Front suspension as stiff as a board.
- 93 4runner engine removal i need help!
- Refinish Steering Wheel?
- 1988 toyota truck stuck in low
- 1986 Xtra cab stock shifter knob?
- bad vibration, sqeeking, and tire is at an angle :D
- 22re timing.
- high pinion flange bolt pattern v v6 driveshaft
- 94 pickup overheating
- 94 Toyota 2WD Auto to Manual Questions A43D Delema
- face lift and headlight upgrade
- Ecu 3.0l
- Source for AC hose?
- Grizzly locker?
- 94 4runner Procomp 4" lift
- Transmission bearing noise in 4th gear
- Time to upgrade, (5.29's and lockers) need to know who to buy from.
- 94 toyota pickup 4x4 without ac???
- Effect of unseated spark plugs
- 1994 4runner WON'T START
- question about brakes and AC
- AFM/vacuum issues
- SUV stalls at stop sign/light
- auto hub poping
- What to do with my poor exhaust?
- '86 Yota rear end roaring and leaking oil
- Bad Transmission?!?!
- 89 truck wont idle
- Part - 3VZE behind fuel pulse dampener - ID help?
- Metal Insert in the Crankshaft
- It's alive!!!
- Trouble removing window tint
- Tough engine replacement question!
- Rear passenger break locking up
- gauge cluster keeps dieing
- making sure i have my dipstick tube in all the way
- Gas in oil???
- 90 4runner with blown head gasket... repair or sell??????
- up and down idle
- Fill transfer case from top?
- Please help identify and do I really need this??
- 1993 toyota front end rusted (help)
- 3VZE O2 Sensor
- Headers!!!???
- Cruise control stopped working
- Parts list for SAS on 87 Yota....
- 91 4runner engine knock
- 22re running super rich at idle
- Exaust sound
- cut-out gasket material for tstat housing?
- front end sounds? creak or groan when I turn
- obscure: vf1a oil pump seat o-ring part number?
- 1987 4runner power windows help
- $100 for an regular battery?
- 3.0 cams and valves
- New truck owner needs advice on 92 4x4
- 1993 4runner overheating woes...
- 1993 3ZVE - Camshaft Bearing Cap Bolts??
- truck is misfiring i guess
- Clutch/Flywheel for 94 4runner 3.0
- Reviving a long-dormant, low-mile 22RE
- 1993 toyota pickup running weak?
- Popping noise when braking....
- 87 P/U come with drive flanges????
- 91 Toyota Flatbed dually question about driveshaft
- 91 3.0 overheating, waterpump?
- Mystery Screw/Valve/VSV
- 2nd Gen. 4Runner Windshield Washer Pump Replacement
- CreswellRunner's 4runner Thread
- Total lack of power and miss during idle
- 1991 4Runner Concerns
- Ahhh 3.0 V6 engine troubles!!
- 89 4runner amazing exhaust video (for those who said it sucks)
- Rear drive line cv options???? Please help????
- Need help choosing spark plug
- 87 22r Vacume and Emissions Question?!
- circuit opening relay /fuel pump
- Daystar Rear Lift questions
- 87 turbo won't idle at first, but runs great after driving
- '87/'88 (lower intake?) coolant hose availability
- 3.0 idle problem, codes for lean and rich
- V6 3.0 Intermittent Power Loss, code 71
- Instrument cluster swap - '91 1-ton dually
- Rebuild auto trans or do the 5 speed swap?
- carb to EFI Turbo?
- 3VZ Idle and hesitation issue
- cut out fender flares
- Timing Chain Rattle {Video}
- IFS diff Issues.
- Broken speedometer cable. How to replace?
- 91 4Runner...should I part it out?
- Sealant for gasket on timing guides
- 1992 toyota pickup Idle problem!
- 1991 T4R - Rear Window Switch and Window Lock Switch ?
- Zuk Mod (rear suspension sag fix) first impressions- '87 pickup
- HELP...New engine running crappy
- Pulsation Damper?
- Intermittent stumbling up hills and accelleration
- performance engine builder in Las Vegas???
- 88 4Runner (3.0 V6) Day 1
- i have a sexy 89 4runner, and i just got window tint (pic heavy)
- o2 sensor location
- 95 4runner coolant leak only after engine is off
- Steering stops grinding
- Auto guy
- famly truck
- New guy here. Just saying hello.
- A/C and diving RPMs
- Loses Power when cold
- New guages in dash, guess what I have found.
- Fuel sending unit 86 pickup
- Slick 50 - Not what it used to be!
- going to be pulling and swapping motors 22re
- Have a few questions about what size lift to get
- please clarify this sensor issue 3vze
- Help me decide, new Radiator.
- Hesitation on my 89 - 4runner. Solved!
- How much can you cut out of 4runners rear wheel wells
- Lift ? what size bj spacer and block?
- power windows failing to work all the time
- 4Runner 1991 Suspension lift question
- 1990 V6 4runner takes forever to start
- Electric fan considerations and opinions
- bad mass air sensor?
- 22 re exhaust manifold
- 86-89 wiring hardness
- check engine light on while car is off
- leaking #4 fuel injector and truck wont start.
- Breaking the steering lock.
- No start after head gasket replaced
- my new 600 dollar yota
- 1986 4 runner tranny?
- '91 3.0 A/C question......
- Truck no-go, flashing OD light, code 42
- need to find new clutch pedal bushings
- 22R-E Vacuum lines..
- guidance on where to purchase new engine for my 94 Tacoma
- truck won't crank over
- rebuilt W-56 question?
- 94 toyota pickup 4wd question
- First Head Gasket & Timing Chain
- Code 52: 89 22RE
- diagnose trick with paper clip
- 88 3.0 help please daily driver not starting
- blazeland kit/rear axle swap
- New member with idle issues on an 88 4runner.....
- 94 4Runner No Start, No Spark, No Pulse
- '92 replacing full exhaust system
- When it comes to glass, what yrs compatible with a 95?
- TDC Help
- intermittent heater/blower fan?
- Low service port
- do I have the right headlights?
- 22re won't start....
- Relay rod replacement - used OE or aftermarket?
- Not impressed with 63s...who's still old school getting good flex with leaf springs?
- Torsion Bar Question
- How does my new longblock sound? (video)
