92 pickup 3.0 timing problems
Old Aug 3, 2011 | 01:09 AM
mchurch2's Avatar
I got a 92 pickup with the 3.0 and I just built a new motor for it. But when I put the timing. Belt on one of the cam gears rolled out a tooth. Can I adjust that out at the distributer or do I need to redo the timing belt process?
Old Aug 3, 2011 | 02:46 AM
iselloil's Avatar
You have to keep the cams in time with the crank.You cant adjust it at the distributor.Move the cam back one tooth.
Old Aug 3, 2011 | 03:03 AM
mchurch2's Avatar
92 toyota timing
Thanks I kinda figured that but I got a buddy that thinks he knows it all and he is the type that if his mouth is moving he is Probably lieing and he says he use to work at a Toyota dealership but he told me u could adjust it at the distributer but I wanted to be sure that I needed to redo the belt before I actually went any farther
Old Aug 3, 2011 | 03:22 AM
iselloil's Avatar
You've got two cams,now one is out of time with the crank,one in time.How would the doing it at the distributor work?When we do timing belts on anything. We mark the old timing belt at three places,and each pulley.Remove the belt and transfer the marks to the new belt.Then install the new belt.Takes a extra minute, but you know your right when your done.Also you dont have to put the engine at TDC.
Old Aug 3, 2011 | 04:38 AM
mchurch2's Avatar
Thanks for the tip that was almost what I did in the beginning except I didn't mark the belt and when I.pulled the slack out of the belt with the tensioned pulley that is when the cam jumped a tooth.
Old Aug 3, 2011 | 06:22 AM
dropzone's Avatar
Fossilized
Notice your friend 'used to work' if he knew what he was doing he would probably still be there...
You can download the fsm in my sig...
Old Aug 4, 2011 | 03:14 AM
TNRabbit's Avatar
That would work if his "friend" hadn't done the last timing belt change at the dealer.....
bigblue82
10
Jul 6, 2015 08:27 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
bprice0077
Jun 25, 2015 07:36 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
nyk08trx
Jun 18, 2015 09:01 PM
