Safety Cancel?
Old Dec 3, 2006 | 04:42 PM
atistang's Avatar
Safety Cancel?
My 86 P/U has a button on the dash that says "Safety Cancel"
Anyone know what that does?
Old Dec 3, 2006 | 04:53 PM
Mister Willie's Avatar
Is it maybe the same thing as the clutch start cancel?
Old Dec 3, 2006 | 05:50 PM
atistang's Avatar
idk, I'll try that tomorrow
Old Dec 3, 2006 | 05:54 PM
neilan's Avatar
my 87 has the same thing. Mine is modified thoguh so you have to press it to start the truck. It is the same thing as the clutch start cancel
Old Dec 3, 2006 | 09:03 PM
ToyYoda's Avatar
when your key is in the on postion and safety cancel is on, you're able to start the truck without pushing the clutch down.
Old Dec 4, 2006 | 07:03 AM
eric-the-red's Avatar
Just make sure it's in neutral though
Old Dec 4, 2006 | 06:29 PM
atistang's Avatar
thats kind of an odd feature
Old Dec 4, 2006 | 07:14 PM
jusfloorit's Avatar
Careful! The safty cancel button turns your truck into an animal! Just kidding, it's if you should happen to stall out climbing a hill in 4low in 1st and instead of trying to reapply the clutch and slipping down the hill, you simply use the starter to get her moving and fired up again. I use it to warm her up without having to climb in and push in the clutch.
Old Dec 5, 2006 | 12:33 PM
ToyYoda's Avatar
And it's exciting when it's not!
Old Apr 26, 2010 | 09:21 AM
Stevesk88's Avatar
Wow! Hey i was just gunna post the same exact question. I couldn't figure out what that silly thing was, i'd press it while the truck was already started and it wouldn't go off unless i turned the truck off. I thought i would have a good one for the tech's too...
Old Apr 26, 2010 | 09:38 AM
hunter4runner's Avatar
if its in reverse and standing in the cleft of the door its scary as pee
Old Apr 26, 2010 | 09:49 AM
Redeyejedi's Avatar
but you still have to use the clutch to shift right? it's not a manual/auto tranny conversion button right?
Old Apr 26, 2010 | 09:53 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
ding! ding! ding!
And on the subject of warming up... I used to pop my TC in neutral and my tranny in 5th (turns the slowest). So when I got out to it, my truck was warm and so was my engine and tranny...
Before, I'd get harder shifting from the thicker fluid until it warned up...
And yes, I am in the "too lazy to get in my truck to push the clutch in" category
Old Apr 26, 2010 | 09:55 AM
yotaman85's Avatar
it just allows you to start the truck without pressing in the clutch. you can also use it to get you a short distance with the starter if your craps out motor on you. hell i've seen a couple low geared trucks use the starter to climb up rocks..
Old Apr 26, 2010 | 10:37 AM
peow130's Avatar
I've used it where i need my foot on the gas, and my foot on the brake. Like if i was flooded on a steep hill.
And it's a great way to stay in shape!
Old Apr 26, 2010 | 04:10 PM
I have done UNREAL stuff with my OEM starters... IMO, there is no other starter... Denso's are tha bomb! Every other starter only wishes they were a Denso...
Old Apr 26, 2010 | 06:27 PM
mattaway's Avatar
I wonder if anyone else will get that?
Old Apr 26, 2010 | 08:23 PM
Tubbyfatty's Avatar
I did hahaha
Old Apr 28, 2010 | 12:47 PM
Jay351's Avatar
Clutches are for nooobs Float the gears!
Old Apr 28, 2010 | 11:19 PM
Yotapowa's Avatar
I laughed. and Jay, when you say float the gears, you mean shifting without the clutch right? I can do that, I always wondered if it was real bad for your tranny or not..
