Safety Cancel?
Old Apr 28, 2010 | 11:49 PM
Jay351's Avatar
Yep. Its fine.. untill you screw up and grind the living chit outa the gear
I used to be able to drive to work (35mins at 2am) only using the clutch to start off from my house..
Old Apr 29, 2010 | 04:33 AM
ET's Avatar
ET
one thing i've always wondered about clutch start cancel. is there a reason why there needs to be a light behind it until you turn the truck off?
Old May 2, 2010 | 02:25 AM
atistang's Avatar
to remind you that it is on, this way if you stall the truck you know the clutch is not needed to start it
Old May 2, 2010 | 07:05 AM
SoCal4Running's Avatar
Originally Posted by tried4x2signN
ding! ding! ding!
And on the subject of warming up... I used to pop my TC in neutral and my tranny in 5th (turns the slowest). So when I got out to it, my truck was warm and so was my engine and tranny...
Before, I'd get harder shifting from the thicker fluid until it warned up...
And yes, I am in the "too lazy to get in my truck to push the clutch in" category
I do the same but put it in 2nd gear as that is the gear it doesn not want to shift into untill warm.
Old Aug 3, 2011 | 11:38 PM
  #25
Jordanlawrence's Avatar
I started my truck this morning with the safety button not knowing I had the truck in 1st gear and nearly ran myself over! I wasn't even reallyy in my truck I was standing outside and I reached in and put the key in and cranked it over. Scariest thing ever
Old Aug 4, 2011 | 06:50 AM
  #26
tj884Rdlx's Avatar
Originally Posted by atistang
My 86 P/U has a button on the dash that says "Safety Cancel"
Anyone know what that does?
occasionally a passenger notices that and asks me the same thing. my answer is usually:
"don't push that! all hell breaks loose!"
or,
"in an emergency, it blows the top off. yeah, the top, see? it comes off."
it's especially fun with the passengers who are easily confused by the 4Runner's second interior door handle.
for a while my front handle wasn't unlatching, so they'd fail and i'd direct them to "use the other one", which would blow their mind.
anyone else use 4Runner quirks to mess with their friends?
83yotastockR
11
Nov 10, 2015 06:54 AM
83
18
Sep 21, 2015 06:15 PM
LucasF249
Sep 8, 2015 08:06 PM
zz_denis
Sep 6, 2015 03:43 PM
