Pre 84 Trucks 1st gen pickups
1980 longbed defrost problem
Old Sep 6, 2015 | 10:42 AM
LucasF249's Avatar
My truck won't pass safety due to my dash lights went out and my defrost doesn't work. Any suggestions on the defrost problem? Thanks!
Old Sep 6, 2015 | 02:44 PM
old87yota's Avatar
Welcome to Yotatech!!
Did these problems start at the same time?
When you say your defrost doesn't work, do you mean the blower will not work on any fan speed or no air comes out of the defrost vents when you turn the fan on and select defrost?
Did anything stop working at the same time as these problems?
Check for blown fuses and clean ground connections.
The more information you can give us, the better answer we can give you!
Old Sep 6, 2015 | 03:27 PM
LucasF249's Avatar
I think I blew a fuse with the dash lights, any idea where that fuse might be? It doesn't say on the fuse box. When I bought the truck the lights worked fine up until the other day. The defroster hasn't worked in awhile I'd assume.
I just checked to see if it blows anything hot/cold, I couldn't feel anything coming through. If there is any other misc info I can provide please ask if I'm missing any good details.
Thanks for the reply! I'v been stressing this problem for awhile now.
Old Sep 6, 2015 | 10:18 PM
dropzone's Avatar
Fossilized
There isn't that many fuses in the box, pull them onE at a time and reinstall as you go until you find a blown fuse.
Old Sep 8, 2015 | 01:23 PM
mwisham's Avatar
Can you hear the blower motor running when you turn the switch on? My 1980 is easy to hear the blower motor running. If you don't hear the blower motor, then it more than likely is a blown fuse. If the blower motor works and there is no air out of the ducts, a duct hose may be off or the cables that switch the air flow may be off or broken.
Old Sep 8, 2015 | 08:06 PM
kawazx636's Avatar
Check the rheostat (dimmer switch). A lot of times that can fail and render you lightless.
The defrost could just be a poorly adjusted cable on the slider mechanism (assuming the blower is working)
80Truck
Oct 12, 2025 07:25 PM
MO transplant
Apr 23, 2023 11:58 AM
DrZero
18
Jul 24, 2015 11:31 PM
msane99
Jul 17, 2015 10:13 AM
msane99
Jul 11, 2015 08:08 PM
