1991 T4R - Rear Window Switch and Window Lock Switch ?
Old 07-25-2011, 12:07 AM
El_Estrago's Avatar
Hi,
Just finished installing an aftemarket CD player into my T4R today and now my HVAC light is no longer working. I tried taking everything apart and checking the connections and nothing worked, so I will be changing the bulb tomorrow morning to see if that is the problem. I wasn't too sure if the rear window switch and lock switch that are on the center console are supposed to be illuminated? If they are, then I have something wrong there too.
Any input would be greatly appreciated
Thank you,
Old 07-25-2011, 03:45 AM
Staff
Terrys87's Avatar
Sounds like you wired up wrong. I would undo your CD. I did that once and had grounded something that wasnt supposed to be grounded.
Old 07-25-2011, 03:18 PM
El_Estrago's Avatar
I found the problem this morning, turned out to be a burned out hvac bulb.
06-01-2021 01:51 PM
Johntom240
7
07-13-2015 12:18 AM
AaronM
07-08-2015 07:15 PM
coryc85
07-06-2015 04:07 AM
zd92655
07-05-2015 04:25 PM
Quick Reply: 1991 T4R - Rear Window Switch and Window Lock Switch ?
