22re not starting
Old Aug 1, 2011 | 04:16 PM
chrismhartley's Avatar
22re not starting
i know theres probably 100 threads but i can find anything on this, here the story, i drive home from work about 30 min ride, shut it off take a five minute shower and now it doesnt start, i can hear the engine turnin over but it doesnt start, i checked my fuel pump and it has spark, truck only has 102xxx and its a 93, any other ideas PLEASE HELP ME
Old Aug 1, 2011 | 04:24 PM
helpppppppp i needa get to work tomorrow
Old Aug 1, 2011 | 06:43 PM
ebrake92's Avatar
Fuses would be a good place to start.
Old Aug 1, 2011 | 07:35 PM
john4wd's Avatar
Is there gas in there first? check fuses and then rule out MAFM by taking off top air cleaner cover and look inside you'll see a flapper then stick a long screw driver into it to push back the flapper that turns on fuel pump after you lay it down with screw driver still pushing flapper back, then get in and try starting it, if it doesn't start put cover back on and go on to another salution, Good Luck...
Old Aug 2, 2011 | 04:37 AM
Yota_boy18's Avatar
Check the EFI fuse under the hood. mine did that a couple of weeks ago, I replaced that fuse and fired right up.
bigjstang
Jun 2, 2025 03:56 PM
Yota.Jay
Jul 23, 2015 08:08 PM
bryan34w
Jul 6, 2015 05:53 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
