Bad Transmission?!?!
Old Jul 29, 2011 | 08:51 AM
my-4x4's Avatar
So my newly found beauty has some flaws...its a 86 4runner 22r-e with a w56 5-speed
The problem is...when I put it into any gear I get noise...sounds kind of like loose marbles in the transmission. I hear it the best in 5th....but in 4th gear it goes away completely. When its out of gear it I don't hear any noise from it...
I did some research on here and couldn't quite find my problem or a solid solution. I read that it could be the input shaft bearing or pilot bearing...any thoughts?
Thanks in advance
Old Jul 29, 2011 | 08:54 AM
TNRabbit's Avatar
If you hear it in every gear but 4th, your bearings are toast (4th is direct drive through shaft). I'm betting if you drop the drain plug you'll find a lot of pieces of bearings.
Old Jul 29, 2011 | 08:58 AM
my-4x4's Avatar
I'ma drop the tranny this weekend...which bearing are u betting are toast? And any idea on what price they run?
Old Jul 30, 2011 | 06:21 AM
my-4x4's Avatar
...bump
chuckross1957
Jun 28, 2019 10:19 PM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
