remove crankshaft pulley (not the bolt)
Old 08-05-2011, 07:07 PM
geoduke's Avatar
I got the bolt off no problem by putting the truck in 5th and having my wife stand on the brake.
Any tips on getting the pulley itself off? I can't get leverage on anything to pry it off, does anyone have any tricks?
Old 08-05-2011, 07:12 PM
87 Deathtrap's Avatar
I sprayed mine with some PB Blaster and tapped it with a rubber mallet to brake it loose, then it just slid right off.
Old 08-05-2011, 07:15 PM
rworegon's Avatar
A steering wheel puller works great if it's really stuck after hitting it with a penetrating oil like PB blaster.
Here's one example:
http://www.harborfreight.com/46-piec...set-37824.html
Your local auto parts store may have a kit like this that they loan for a deposit fee.
Old 08-05-2011, 08:04 PM
85gijunk4x4's Avatar
throw a gear puller on there!! hell, if it bends, i always like to say "man made it, man can fix it"
you can always find a new pulley, its good to get one off without damage, but if you cant, theres plenty of spares. stuff happens man, what the heck ya gonna do?
Old 08-05-2011, 08:08 PM
geoduke's Avatar
Thanks guys. I was hoping there was a Friday night work around.
A puller is probably a good thing to have, especially for $10.
Old 08-05-2011, 08:11 PM
actually, while ur pulling it with the puller, apply LIGHT pressure, and then apply heat at the same time. something stronger then propane, and lighter then oxy-acetylene. maybe map gas?
Old 08-06-2011, 04:31 AM
xxxtreme22r's Avatar
if it's that tight you might wanna order some new crank keys as well. I had that problem as well, had to use a puller the first time. It was because as some point the P.O. damaged those crank keys. 3vze only needs 1 according to LCE.
One of the few things I would order from LCE: http://www.toyotacatalog.net/M1WebGe...7-D468AD6C4C1D
Blamalam
03-12-2022 07:34 AM
TJWilly
07-31-2015 02:05 PM
yoterr
07-24-2015 04:29 AM
dinks07
07-15-2015 05:34 PM
Snort
07-09-2015 03:58 PM
Quick Reply: remove crankshaft pulley (not the bolt)
