Igniter coil resistance test
Old Aug 4, 2011 | 03:52 PM
xylicon's Avatar
I've read numerous "22re is missing" threads, I've tested everything and it checked out except for my signal generator testing at 206 ohms.
The range is 140-180
I can't find anywhere where I can order just the signal generator.
Old Aug 5, 2011 | 09:41 AM
xylicon's Avatar
I'm trying to find a new signal generator but the dealership says I can't just get that one piece, that I need to get the whole distributor is that true?
Old Aug 10, 2011 | 03:17 PM
xylicon's Avatar
Well I got a new signal generator from RockAuto.com its made by Airtex part No. 4P1151, however its not within the specs that my FSM calls out for. I don't know if I should use it or not? Anyone chime in?
The resistance is within Airtex's specifications but not Toyota's.
Old Aug 10, 2011 | 03:22 PM
jdw1's Avatar
Are you checking the resistance while it is at operating temp or cold? The number will drop when it cools. trd parts for you shows having the pickup coil you can buy seperate.
Old Aug 10, 2011 | 03:26 PM
xylicon's Avatar
Checked while cold.
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
izzmee
Aug 17, 2015 10:20 AM
Sidherish
Aug 3, 2015 07:17 PM
mlavery85
Jul 12, 2015 10:33 AM
