Gas in oil???
Old Jul 28, 2011 | 05:42 PM
bamacooner1591's Avatar
Gas in oil???
I checked my oil the other day and noticed it was real thin and smelt like gas, its not my rings, the diaphragm busted in my mechanical fuel pump. I ordered a new one and it came in today. My question is, do all mechanical fuel pumps require the 1/4 inch spacer gasket? Because it notes on the instructions if it doesn't have it, it can overwork itself and cause pump failure. But my older 22r didn't have one on it?
Old Jul 28, 2011 | 05:51 PM
xxxtreme22r's Avatar
Yes all of them need that spacer. As far as I know anyway.
Old Jul 28, 2011 | 06:02 PM
It just has me confused because i had a 1980 4x4 with a 22r with no spacer plate, never had a problem.....
Old Jul 28, 2011 | 06:05 PM
1980 with a 22r? you sure? IIRC I don't think so. 20R yeah but not a 22r. 22r's wern't made till 81.
Old Jul 28, 2011 | 06:08 PM
85gijunk4x4's Avatar
20r = 1975? to 1980
22r= 1981, 82, 83 and then optional up untill 1995.5
and yes, spacer is pretty much manditory
Old Jul 28, 2011 | 06:14 PM
i know 100% it was a 22r..it was converted from a 20r. Are you sure about a spacer being manditory? Cause my 80' model did not have one and ran fine
Old Jul 28, 2011 | 06:42 PM
I am 100% sure now that all need the isolator. Including at least the 79-80 20R.
http://www.utoyot8.com/FullImage.asp...++%2920R%2c22R
23100C INSULATOR, FUEL PUMP
Replaced by: **923-06009 **923-06001 1979.08-1983.07 20R, 22R.. RN3#, 4#
http://www.utoyot8.com/FullImage.asp...308-8808%2922R
Replaced by: **923-06009 **923-06001 1983.08-1988.08 22R.. RN5#, 6#, 70
Old Jul 28, 2011 | 06:48 PM
okay, you made you point lol for some odd reason my old yota didn't have one. but ill be sure to put one on this one
Old Jul 28, 2011 | 06:52 PM
also, another question i have..can the fuel return line be blocked off with out any issues?
Old Jul 28, 2011 | 06:54 PM
I woulnd't block it off if running the aisin carb, weber it's ok as long as your running a regulator at 3.5-4 psi. Which is how I have mine set up, however, it does make the fuel pump work more and it also makes it louder. I've been running mine that way for almost 15K now without any issues that I can see.
Old Jul 28, 2011 | 06:57 PM
I have the Aisin carb, i guess i'll run it lol im just trying to make this truck as sinple as possible
Old Jul 28, 2011 | 07:45 PM
your old yota was driving on borrowed time....
Eggslinger
Jun 8, 2019 03:32 PM
skoti89
Sep 11, 2015 07:46 AM
adammtb
Jul 27, 2015 11:57 AM
Yota.Jay
Jul 23, 2015 08:08 PM
ryerye13
Jul 14, 2015 08:27 AM
