A/C Quits when hot
Old Aug 3, 2011 | 01:12 PM
Yotard's Avatar
A/C Quits when hot
I have been battling the AC on my 95 4Runner this summer. I keep it in the garage which stays fairly cool. If I turn the AC on when I start the truck up from being cold it works fine for about 20min or so then I can't get it to work again. If it has been parked outside, it will run for 1min then not anymore. I can feel the clutch kick in and back out right away but the light on the dash stays lit. I thought it just was low on refrigerant so I checked that but it wasn't the problem. I know its not the clutch or the compressor. What do you guys think?
Old Aug 3, 2011 | 02:12 PM
punkelberg's Avatar
remove and carefully clean the evaporator unit under the glove box. Replace the expansion valve while you're in there. Did this to 2 of my 4runners with the same issue and they both blew FRIGID after.
Ktm526
Oct 7, 2015 05:14 AM
LotOMiles
Sep 14, 2015 11:45 PM
Tacoma1313
Sep 8, 2015 01:27 PM
--Oz--
Sep 6, 2015 01:06 AM
moparbay
Sep 3, 2015 12:48 PM
