Lift ? what size bj spacer and block?
Old 07-22-2011, 02:31 PM
KenC's Avatar
I just picked up a 1991 toyota pickup,it currently has a 2" bodylift and 33" street tires but it slightly rubs at full lock.i am getting mud tires soon and was looking at ball joint spacer kits and blocks on ebay and wanted some opinions and suggetions.I want to know what size bj spacer and block to use without cranking the torsion bars up to much but keeping the ride height even.the reason i ask is cause i had a jeep cherokee and i installed a 1" shackle in the rear and a 1.5" coil spacer up front and for some reason it sat a little higher in the rear and i dont want my truck to look like that
Old 07-22-2011, 02:33 PM
MaK92-4RnR's Avatar
just get a 1.5" BJ spacer and an add a leaf then.
Old 07-22-2011, 02:37 PM
KenC's Avatar
only reason i was debating the add a leaf is cause i had them on my jeep and it rode rough unless i had a trailer hooked up and im afraid with the truck being light in the rear that it will be even worse please correct me if im wrong
Old 07-22-2011, 02:39 PM
waskillywabbit's Avatar
http://www.wabfab.org/IFS-Lift-Kits/...-products.html
:wabbit2:
Old 07-22-2011, 02:41 PM
xxxtreme22r's Avatar
a 4lb sledge is cheaper then a 2" suspension lift, just sayin.
Old 07-22-2011, 02:45 PM
MaK92-4RnR's Avatar
oh no doubt it will ride rough, but you were asking for a lift suggestion, not a quality ride blocks ride like poo poo too though.
i'd just beat your pinch weld in.
Old 07-22-2011, 02:51 PM
KenC's Avatar
the truck need new shocks anyway so i figured it wouldnt be a big deal to get another inch or two at the same time,i already put 4.88 gears in the rear so i can get up the pa hills but i still need to do the front.i traded my trans am for the truck + $ so i have some $ to play with.i really appreciate the suggestions even though im not big on the hammer method
Old 07-22-2011, 02:53 PM
BMcEL's Avatar
A 1-2" block will ride nearly identical to stock (slightly more axle wrap under hard acceleration) and definitely not as rough as an AAL.
Old 07-22-2011, 03:44 PM
FourwheelinVT's Avatar
I used a pair of 6 inch shackels (1.25 inches of lift) with the stock springs and it rides great
Old 07-27-2011, 04:40 PM
KenC's Avatar
need any other parts to complete lift?
i have a 1991 toyota pickup 3.0 5 speed with a 2" bodylift,black d window rims and 33x12.50 tires and 4.88 gears.i got bj spacers,u bolts and blocks off a kid i work with brand new 150 (1.5" spacer and blocks),i ordered a set of shocks for the lift is there any thing else that i will need to put it on?
09-04-2015 09:27 AM
coffey50
07-28-2015 10:55 AM
Gravel Maker
RuffStuff
07-27-2015 06:53 PM
whereAreMyPants
07-22-2015 03:32 AM
Yotoder865
07-09-2015 07:51 PM
Quick Reply: Lift ? what size bj spacer and block?
