AC not cold, compressor working...
Old Aug 5, 2011 | 06:01 PM
QuickSilver74's Avatar
i think it may be the expansion valve. i got the AC refilled today with 134A and it blows cold for a few (very few) minutes and then turns warm. i have an electric fan set to turn on with the compressor.
the shop said the low pressure was acting strange and fluctuating between 20-50 and they thought it was a expansion valve issue.
is there a guide on the replacement of the valve? if not do i have to remove the entire dash or can it be accessed by going behind the glove box?
truck is an 89 with factory air
thanks
Old Aug 6, 2011 | 06:07 AM
BigSwole's Avatar
I have the same issue. Ill try and search it later
Old Aug 6, 2011 | 01:51 PM
The MAN's Avatar
discharge the system and disconnect the two pipes at the firewall... you should be able to pull the evaporator box out by removing the glove box... it is a separate box from the blower and heater boxes... you shouldn't need to pull the dash out unlike domestics
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Ditch Doc
Oct 27, 2015 03:20 PM
Badlander
Oct 10, 2015 08:05 PM
bryan34w
12
Sep 30, 2015 02:50 PM
