PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 [85] 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. New member wanting to know where to start
  2. driving with blown head gasket
  3. Quick question about milage calculation and re-gearing..
  4. rear end vibration !!!!!!
  5. brake lock up
  6. 3VZE - Fuel Cut Solenoid
  7. fuel door hinge help !!! I need your wisdom or ideas
  8. Pitman Arm Problems
  9. Fuel Sending Units
  10. 1995 4Runner with old ecu
  11. Instrument Cluster Wiring
  12. Another rear sag thread
  13. Weird cluster light issues on a 1990 4R
  14. 22re timing adjustment
  15. 1st time rebuild, getting started help? Las Vegas
  16. Front End Alignment:Where to Start?
  17. new member sayin "hi"
  18. 22R Carb Swap - Gasket Question
  19. Rear bumper removal. 1st gen 4runner
  20. '89 4runner rear seat back pins/bolts?
  21. radio ground wiring
  22. grey smoke, smells like fuel, burns SO rich
  23. What do I need to put ac in my yota
  24. New HG installed. Yotatech Rocks!
  25. Aisin hub bolt issue
  26. 91 22re, will crank but wont start. WHATS WRONG?!?!1one
  27. losing coolant and surging idle 22re
  28. Trail gear coupon?
  29. CTS help
  30. 1989 4Runner (22re) stalls and will not start after warmed up
  31. wire tach to an SR 5 cluster. 85' runner??
  32. Anybody know what this is?
  33. 1986 extended cab 4x4 axel options
  34. 93 3vze couple questions
  35. Thermostat bypass hose
  36. 93 Toyota Pickup 2WD Tranny & Rear End Oil Capacity ?
  37. TOYOTA decal not sticking to tailgate... cold weather
  38. Fresh 92' 22re Wont Start. WEIRD.
  39. Shifter Moving All Around
  40. Front third swap. Now its binding up in 4x4!
  41. Help me with my clutch.
  42. '86 SR5 brake lines
  43. Warm Start Issue Still getting me...
  44. heater not working as well as it should-water pump?
  45. 1988 toyota 22re
  46. New 'Yota w/pics...and "?'s"
  47. that damned clutch pedal bracket got me
  48. Changing headlights on 1987 4x4 - do I really need to remove the grille?
  49. code p0440
  50. 1st Gen 4Runner: Aftermarket shackle width question
  51. Auto to manual transmission
  52. Removing unneeded smog equipment?
  53. Anyone have any pictures of new Head Gaskets Installed? 3.0 V6
  54. Well I'm an Idiot (Knocking/clacking noise)
  55. Stock LC shocks vs ES3000
  56. crappy idle when cold outside?
  57. SPARKS89 Build-Up
  58. Push bar swap???
  59. can a fuel pump run slow?
  60. Trail gear bumper painted?
  61. New powers testing pump & idle up valve
  62. 1992 22re Pickup - Major Oil Leak
  63. 94 pickup has violent vibrations in reverse
  64. 36-38s w/ IFS. who has it? pics?
  65. Christmas time! $100 spending limit.
  66. Help with choosing what trans will work
  67. is TOTAL CHAOS the only maker of lower a-arm uniball conversion?
  68. 22re first crank no start second crank fires rite off
  69. Another head gasket thread
  70. 3VZE code 25
  71. sbc with TBI into 88 yota
  72. Exhaust system
  73. 94 yota deluxe 3.0 5 spd Starter problem
  74. bad knocking in 2H
  75. 22RE burps / deep rumbling noise at higher RPM
  76. 2PC Dash to 1PC Dash swap Complete!! MUST READ!
  77. 22re ring seating/head gasket question
  78. another 3.0 to 3.4 swap inquiry
  79. 02 gears in a 87?
  80. What is the best width to go with on a custom front housing?
  81. tooth pattern help
  82. What is a T series Toyota?
  83. Converting auto to 5 speed manual
  84. Drilled out oil pressure sender - Need help
  85. 1990 Toyota pickup, 7ft bed to 6ft bed.
  86. Shock preferences
  87. 3.0L Backfiring and general loss of H/P and Gas mileage
  88. 87 22R installed new head now cant et timing at right.
  89. frustrated
  90. 86 22r Carb not taking fuel
  91. Quick question regarding valve adjustment
  92. sucess story!!!!!
  93. 95sr5z's 4runner Build
  94. fiberglass insulation for rear panels on 1st gen 4runner
  95. fuel issues
  96. 1st Gen 4Runner: Was fixing my rear defrost, now window issue
  97. help solve sputtering for me
  98. 4 runner starts but cuts off quickly
  99. My new Wheels and tires
  100. 4Runner Dash Clock in P/U
  101. 2 door 4runner info
  102. Front wheels toe in while in 4WD
  103. 22R won't start, has spark
  104. erratic idle, timing codes 52 and 22
  105. Rebuild Start Help! Engine runs fast
  106. '88 22RE O2 sensor question
  107. Wheel Swap
  108. 2nd gen e brake handle in 1st gen
  109. Front IFS swap question.
  110. 1990 4runner radiator question
  111. 94 Crusier 1 FZ-FE intermittent code 26
  112. Shacking between 50-65
  113. trouble finding diagnostic line, previous owner engine swap
  114. 3VZE loosing coolant
  115. AC clutch gone bad
  116. Front Bumper Bolt Sizes?
  117. 1987 22r 4x4 l/b with 30k og miles
  118. Dont know what this pulley is. please help!
  119. Timing jump or otherproblem?
  120. '95 4Runner won't start, won't turn over
  121. (22RE) New Coolant leak....am I in trouble here?
  122. mystery bracket on 1988 v6 4runner
  123. 95 4 Runner with 22re.. Starting problems?
  124. Advise on new head
  125. Brake light issue only when headlights on
  126. Very Low Idle, Temp/Tach Gauges Malfunctioning
  127. transfer case compatability?
  128. Introduction and a Few Maintenance Questions
  129. 1994 Cold Start Injector Fix
  130. Back window goes down but wont go back up
  131. First gear trouble 1986 toyota pickup 4x4 Automatic
  132. Rim offset
  133. 89 toyota truck running hot
  134. 93 SR5 3VZE with 2 problems
  135. 22RE New head gasket but now dripping antifreeze off oil pan? where is my leak?
  136. Hard time finding front Mudflaps....94 P/U
  137. adding a resonator to 22r exhaust
  138. O2 Sensor/Exhaust Pipe Warped; Sealant?
  139. Knock sensor location
  140. 95 4runner won't start, shop could not get running.
  141. '88 22RE 4x4 Burning Oil 3k into a "rebuild"
  142. what parts from 3.4 can i use on 3.0?
  143. '87 Wheel about to fall off!
  144. 22r to 22rte swap in 1987 pickup 4X4 HELP!!
  145. Fuel Pump doesnt get power, relay problem?
  146. New Bumper
  147. My 86 needs love! Engine problems first though.
  148. Stock height?
  149. OVERDRIVE JUST...Didn't Kick In Yo.
  150. Auto trans not shifting int. replaced solenoids already.
  151. Bleeding / Burping Cooling system help
  152. Location of the reverse lights on an 87 4runner
  153. Yoder idears.
  154. 4runner questions
  155. Fromt diff. mounts bent!!
  156. problem cant understand whats going on
  157. Instrument cluster removal
  158. Internal coolant leak
  159. '92 A/C control assembly problem???
  160. Leak from back of engine
  161. 94 22re help
  162. Need some advice
  163. 1st gen bed on a 2nd gen pickup??
  164. 95 3.0 Timing Belt / No Start Help ASAP Please
  165. Leaking master cylinder.
  166. Spongy brake issue
  167. Short Throw Shifter
  168. Name who makes them?
  169. 91 Toyota SR5
  170. speedometer drive gear spins freely?
  171. My Youngest Son's First Yota....Pic Heavy!!!
  172. 1988 4X4 Driver Side Window With Vent Need Help Finding
  173. electronic timing advance
  174. Broke Timing chain cover at Head bolt 87 22r pickup - replace?
  175. need help 87 4runner running hot
  176. Transmission leak fix? RTV vs. Paper Gasket
  177. Missfire after head sealed
  178. 91 Toyota fuel problem 3.0 v6
  179. Please help with questions on 3 vacume hoses 4runner 3vze
  180. Buying 1988 sr5 4x4 xtra cab
  181. 1990 22re pulsing idle
  182. Rear Seat mod tundra rear bench to pickup
  183. 3VZE- Oil pan removal HELP
  184. Starting problem with my 92' 4runner.
  185. Where the h*** did my power go?
  186. Fresh head gasket still blowing white smoke
  187. 91 4runner wont turn off
  188. 93 22re computer question
  189. transmission ID and interchangable
  190. The mysterious sound....Hey SCOOBY!
  191. Problematic rear window thread? What's That?
  192. Brakes acting up
  193. 89-94 3.0 swap, wiring issues?
  194. 1990 4runner emissions issues. Have specific numbers, looking for some help.
  195. 3vz-e help!!!!
  196. just an new guy
  197. lug nut question
  198. short throw shifter
  199. Hard to get I gear sometimes
  200. 89 drivetrain noise
  201. Confused about axle gearing formula.
  202. Calling all IFS guys with big tires- 35's and up!
  203. Rear driveshaft offset?
  204. Carbs and Alien Space Parasites.
  205. HELP! Toyota 22R cutting out and running rich
  206. NEED HELP!!! ASAP tranny seals
  207. 89 engine to 86 truck
  208. ground wire near coil. where does it go?
  209. Still Shakes HELP!!!!
  210. Toyota Axle Swap on Mazda B2200
  211. Oh crap... am i ruined?
  212. Funny Noise
  213. Fat Bobs ball joint spacers
  214. Radiator question???
  215. need an engine wiring harness
  216. 3.4 swap overheating, top is hot, bottom cold
  217. sr5 seat-spring is killing my back
  218. Blown head gasket 1993 3.0
  219. 92 22re cold-missing
  220. 88 4Runner 22re - good deal or money pit?
  221. Turn signal bulb or something else? Blinker issue, video inside
  222. 88 22RE injectors not injecting Wire guru needed!!
  223. 95 4x4 runner 3.4 swapped with the old 3.0 auto tranny question
  224. Problem indentifying tranny
  225. 4runner pulling to the left in 4wd
  226. Knock sensor relocated - Code 52 CEL still present
  227. 22re - Where does this connector go?
  228. fuel system cuts out when I accelerate onto highway-95 4runner 3.0
  229. !!!!!! HELP!!!!!!! I need help please
  230. !!!!!! HELP!!!!!!! I need help please
  231. Diagnosing my fan clutch
  232. 22RE Fuel Injector Alighnment - Help
  233. 86 22r 2.4 carb hoses attach to
  234. Clutch Pedal HELP
  235. 3vz engine tick
  236. Confusion over Japan built part, 3.0 4runner
  237. Steering shaft compression
  238. wierd idle issue on startup after valve cover gasket replacement
  239. 86 toyota 22r. runs bad after new dist.
  240. 87 4runner wont idle/missing 22re
  241. Radio Wire Colors?
  242. 3VZ-E Headgasket recall?
  243. R151f tranny for 87 4runner
  244. swap stock carb for webber
  245. 94 4runner has bad wobble
  246. Clutch won't disengage
  247. transmission question: 1992 Toyota 4x4 v6 automatic ext cab
  248. electrical problem 1989 toyota pickup 22re
  249. heater air temp at vents
  250. 92 pickup cel code 24 and 25
