Drilled out oil pressure sender - Need help
Been on here a few weeks reading up as I work on my 86 runner (22RE-C). All kinds of things been done in last weeks and will share later but right now I have an issue.
Started to mount an oil pressure dial and the old sender unit would not come out. Easy outs, reverse drills etc and days later still stuck in there. So tonight I drilled it out with a 3/8's bit and will convert to NPT. I am very worried about the shavings however. I have seen conflicting reports on the oil flow and if these will get picked up by the filter or not. Need help from those that have done this. Best way to get these out? Thank you
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
