that damned clutch pedal bracket got me
Old Dec 6, 2012 | 02:37 PM
machine23's Avatar
to all those who have done the clutch pedal bracket on the 2nd gen 4runners/pickups. it would appear to me that i have to remove a part of the steering column/knuckle part in order to completely remove the clutch pedal bracket... yes or no? i have hit a dead end and would love to avoid removing that steering column if i dont need to
thank you toyota brotherhood
...and yes i did search this forum and didnt find the info i needed
Old Dec 6, 2012 | 06:40 PM
Chip N Sawbones's Avatar
Don't feel bad, it happens to the best of us.
It is possible to remove the bracket without taking the steering column apart or taking the pedals off, at least on my 1989 2wd pickup. If you've disconnected the clutch master cylinder and the brake booster and removed all the other bolts holding it in, the bracket should be loose. It's a tight fit, but you can rotate it clockwise (toward the gas pedal) and pull it out. I removed the trim under the steering wheel, which may have helped. I got my bracket welded up in exchange for two boxes of donuts and a case of pop at my local welding shop.
When you put the bracket back in, I found it much easier to take the brake and clutch pedals off. If you do this, get the bracket roughly where it needs to be and reattach the clutch pedal before you secure the bracket in place. Otherwise you can't put the clutch pedal bolt back in, at least not easily.
Old Dec 6, 2012 | 07:06 PM
PowerstrokeJoe's Avatar
You can but its much easier to take the column out. its only like 4 bolts. I fixed mine in a couple hours. Just lower the column down onto the seat. Don't take it out completely.
Old Dec 19, 2012 | 07:26 AM
Donster's Avatar
From: East Mountain area of Albuquerque, New Mexico
I had to take mine out and weld it. Mine broke at an intersection in Flagstaff, AZ., about 350 miles from home. I was able to "bailing wire" the thing back into some sort of horrible mess, but I was able to drive it home. The OEM bracket is crap. Best to Weld the old one, add some plates to beef it up, making sure not to cause interference with the pedal, and put it all back. There is a top bolt on the bracket that need attention as well, make sure you put that screw back. I did unbolt the column as I recall, it's really not a big deal. Good luck with it.
Old Oct 23, 2013 | 05:03 PM
machine23's Avatar
totally forgot to make my success post..sorry guys, im a yotatech failure.
I ended up doing what the other guy said and unbolted the brake and clutch master cylinders because i had a "derp" moment and didn't realize the bracket was also secured by those bolts. long story short, my problems were resolved and my truck was back on the road shortly after thanks to this forum. Thank you my fellow yotatech members! and if any of you happen to be fellow chivers, KCCO!!!!
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
duncanmc
Aug 19, 2015 03:13 PM
Motomonty
Aug 9, 2015 05:53 PM
Shaun Crystal Gomban
Jul 30, 2015 10:13 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
