tooth pattern help
Old Dec 3, 2012 | 06:13 PM
Mandy Tuning's Avatar
tooth pattern help
please,need some pro opinion,this is a 4.88 yukon on a elocker with .077 shim and .007 bl.
Old Dec 3, 2012 | 06:21 PM
HighLux's Avatar
too deep
Old Dec 3, 2012 | 07:22 PM
this with a .072 shim. this patterns are turning me nuts.
Old Dec 4, 2012 | 07:30 AM
common guys need your help.
Old Dec 4, 2012 | 07:43 AM
BigBluePile's Avatar
lol, tooooo shallow now.
Do you have enough shims?
Are you making sure your calipers are acurrately measure the shims?
Are you using a crush sleeve or solid collar(which at this point you shouldn't have installed in order to do the gear mesh)?
How much pinion preload are you putting in?
Old Dec 4, 2012 | 07:49 AM
Herro prease???
Old Dec 4, 2012 | 07:51 AM
.075" maybe the number you need.
Have you looked thru Zuk's website? www.gearinstalls.com
Old Dec 4, 2012 | 07:56 AM
Boom.
http://www.gearinstalls.com/jake1.htm
Old Dec 4, 2012 | 08:00 AM
thanks for your response.first was a stock 077 shim now using yukon mini kit.triple check the measurement.crush not yet installed.maybe my problem is the preload,my small torque wrench n inches have a large scale.
Old Dec 4, 2012 | 08:02 AM
tonight spend. near 4hours on zuk site.the more iread and compare the readings the more confuselol
Old Dec 4, 2012 | 08:08 AM
It's hard too say exactly what the problem is without being there.
Are you actually MEASURING your shims? That could be an issue too.
Are you lubing the pinion bearings with gear oil to get a good preload?
How accuarate is your CBPL (carrier bearing preload)?
I've built numerous diffs (majority were elockers), and only ONE has "fallin together" on the first shot. I still tripple checked it
Old Dec 4, 2012 | 08:54 AM
ummm.no lube at the bearings.
Old Dec 4, 2012 | 10:44 AM
Fix it yet?
Old Dec 4, 2012 | 11:15 AM
will try this night aftwer work.lookibg for a good torque meter
Old Dec 4, 2012 | 02:11 PM
how about now.
with 10bl
with 7 bl
Old Dec 4, 2012 | 02:15 PM
What's the pinion shim?
Old Dec 4, 2012 | 02:39 PM
.082,lubed the bearings now first shot was at 10bl sec shot at 7bl.
Old Dec 4, 2012 | 04:26 PM
what you think? ok? still out?
Old Dec 4, 2012 | 04:38 PM
ZUK's Avatar
ZUK
Hi Mandy --- I'd like to see you try 094 and if you could load the pattern the same way I do. Secure the 3rd...hold a rag on the pinion flange lightly while turning the ring gear with a 17mm wrench back and forth 3 times.....you will have a good easy to read paint then. 007 is ok on BL
Old Dec 4, 2012 | 05:31 PM
yes sir,will do tomorrow,thanks guys.
