New HG installed. Yotatech Rocks!
Old Dec 8, 2012 | 01:18 PM
LITLRED's Avatar
Still have work to do like but she fired up on the first try.
Old Dec 8, 2012 | 02:12 PM
hgill's Avatar
congratulations! which engine? 22re or 3vz! It definitely feels amazing when you get it running on first try!
Good Luck! Hopefully there arent any leaks or surprises!
Old Dec 8, 2012 | 10:21 PM
LITLRED's Avatar
22RE
2 leaks so far but both were easy fixes. One coolant and one exhaust.
Old Dec 9, 2012 | 03:14 AM
92 TOY's Avatar
congrats. now lets see some pics
Old Dec 10, 2012 | 10:58 AM
hgill's Avatar
Just curious as to how you determine an exhaust leak? is it something obvious like smoke coming out or is there some test.
Old Dec 10, 2012 | 11:38 AM
Philbert's Avatar
+1 for pics! And the exhaust leak finding method...I think I have one too
HGill - any luck on your idle issues after your HG job?
Old Dec 10, 2012 | 04:12 PM
92 TOY's Avatar
for me it was an obvious noise and some condensation coming out where it usually did not come from.
Old Dec 11, 2012 | 12:50 AM
LITLRED's Avatar
It was leaking at the connection between the manifold and Y pipe. One of the round gaskets weren't seated properly. It was a big leak and pretty loud.
I've had a leak there before so it was suspect. When I fired it up the second time I just put my hand down there and could feel the hot exhaust coming out.
Here's some pics.
Napa Exhaust gas test
Spark plugs
Before cleaning
After cleaning
After Deglazing cyllinders
Old Dec 11, 2012 | 01:00 AM
LITLRED's Avatar
I'll share this in case anyone else may have had the same problem.
The first time I had an exhaust leak where the Y pipe bolts to the Exhaust Manifold it was because the pipes that pipes that extend thru the flange on the Y pipe were almost 3/16 in, in spots where the gaskets are maybe 1/8 in thick so no matter how tight I got it it still leaked. I solved it by doubling up on the gaskets.
This time around I ground down the pipe to maybe 1/16 inch proud of the flange. Enough to position the gaskets but still allow them to seal.
the1998sr5
15
Jul 14, 2020 08:35 PM
raptor510
Feb 17, 2017 07:11 AM
Yota.Jay
Oct 24, 2015 08:41 AM
akaphilly
Jul 9, 2015 02:34 PM
