Fuel Pump doesnt get power, relay problem?
Old Nov 27, 2012 | 05:27 PM
22RE502's Avatar
My fuel pump doesnt kick on. I replaced my ecu because a water leak into the cab made it crap out. Trouble shooting why it still doesnt get power and pulled out the glove box to get to the relays. The two fuses were good they had a 10 and a 30 on them I believe. But I pulled the big one out and it had some green corrosion on it. Is there anyway to test this? Or any ideas on different options to try?
Old Nov 27, 2012 | 06:04 PM
Snortin Nortin's Avatar
Hey have you tried shorting Te1 and Fp on your diagnostics plug?? could be wires? these pumps are good!! but u never hear them run man that stumped me years ago when I got my first one ! or do you have power at the pump?
Old Nov 27, 2012 | 06:11 PM
22RE502's Avatar
Havent tried that yet, but the pump doesnt get power at all I dont think, no fuel comes when the keys turned or when you try to crank it. The relay doesnt click either. My fuel level sending unit works though. Thanks for your help though man
Old Nov 27, 2012 | 06:22 PM
exlowridertny9's Avatar
Arrow try this
check the fuel pump ground wire.
Old Nov 27, 2012 | 06:39 PM
jbtvt's Avatar
If your ECU went, your COR almost certainly did.
https://www.yotatech.com/forums/f131...od-cor-252680/
Old Nov 27, 2012 | 07:07 PM
22RE502's Avatar
Well I talked to the guy I got the truck from. He parked it because the engine wasnt getting fuel. He pulled out the ecu and lost it or threw it away, and he said the fuel pump still got power when he checked it with a volt meter. But that was 2 years ago. Im running to the junkyard tomorrow to pickup a new relay for a couple bucks just to see if its a cheap fix. I'll look into the COR tomorrow jbtvt. Thanks for everyones advice
Old Nov 27, 2012 | 07:21 PM
brianh699's Avatar
There is a fuel pump cutoff in the airflow meter, you may want to check the meter. If the ECU thinks there is no air entering engine fuel pump will not work.
Old Nov 27, 2012 | 11:35 PM
wyoming9's Avatar
Red face
Most all relays have a diagram on them .
It is simple to make up some leads to pull in the relay coil (12 VDC ) then measure if you have continuity on the pins for the closed contacts.
You might want to also clean the socket the relay plugs in with electrical cleaner
Old Nov 28, 2012 | 05:49 AM
scope103's Avatar
Yes. With a multimeter. You have an electrical problem, and you need a meter to do anything. It's not like they cost anything. http://www.harborfreight.com/7-funct...ter-98025.html
Originally Posted by Snortin Nortin
Hey have you tried shorting Te1 and Fp ...?
Fp and B+. Don't ever connect Te1 to anything but E1.
The VAF holds the fuel pump on after you let go of the key. With the key to START, the fuel pump should run no matter what the VAF is doing
Originally Posted by wyoming9
Most all relays have a diagram on them...
The COR (Circuit Opening Relay) is a different animal; I don't believe it has a diagram like "ordinary" relays. But checking it is pretty easy: http://personal.utulsa.edu/~nathan-b...38circuito.pdf
Old Nov 28, 2012 | 01:58 PM
ya thats what I meant B+ and Fp !! sorry about that thats power yaay! on my old mustang I just wired it direct to a switch if its a big problem like an ecu or harness or something !
sonic concepts
Aug 16, 2025 03:13 PM
puffin04
Jul 10, 2015 09:17 PM
OffroadRalph
Jul 2, 2015 07:28 PM
rbravo1
Jun 29, 2015 01:34 PM
Dennis140
Jun 17, 2015 10:37 AM
