- Tire wear (more on one side than the other)and only on one tire
- Stock spare / Swing out spare mount
- 41 teeth on the ring gear= 456s?
- Removing valve covers?
- 22r=22re?
- problem after rebuild
- 87 22r Carb issues
- 4Runner rear diff in 2wd PU?
- 5 - 6 lug swap? (2WD PU)
- Factory suspension, 31 10.50's?
- Help finding an Axle
- 1990 Pontiac 3.1L V6 into 87 4Runner
- idler arm
- Tire Trade
- Front Seats for an 86 4runner
- rear end noise???
- What size is the nut on the output shaft of the transfer case?
- 22re dies after chain replacement
- Need a game plan
- front sway bar
- Absolute amazing deal near SD
- Front bumper design
- Intake manifold question 89' truck 22RE
- GOOD looking hood scoops?
- timing for 87 tubro?
- overheating after valve cover job??? HELP!!!
- Transfer Case Rotates
- reed valve replacment
- the truck that just dosent want to live
- 22re exhaust headers and exhaust systems
- NewRunnerPics...maybe
- 94 3.0 melting air breather hose?
- removing ac?
- For you 4WD freaks....
- EFI fuse blowing
- best combo for the job (gears, suspension, tires)
- '95 4Runner on Death Bed
- ARB bumper 2nd gen truck how heavy?
- 2nd gen 4Runner stock height
- Will a instrument cluster from a 2nd gen Runner fit a 1st gen?
- CAN?T GET INTAKE MANIFOLD OFF 22re!!
- 87/88 4runner O2 sensor cluster
- Anyone in north/central Kentucky?
- What is the tcase shift pattern on a 95 V6 4wd?
- NEED HELP QUICK, Transmission install questions
- so i think i blew up my motor today.... now what?!
- rear wiring help
- 1987 4runner turbo no dash lights!
- 88 manual transmission oil - synthetic REQUIRED???
- Air bags with 63" gmc springs?
- It's Hallowee and time for a smoke show - 3vze sea foam treatment
- Electric Fan for my 95' 3.0L, Auto
- Where to go for diagnostic help?
- weird noise
- Need help identifying a/c connector behind grill
- help buying my friend a 2nd gen 4runner
- Blower motor cutting in and out
- 87 4-Runner gets a 22RE to 3.4 swap - auto trans
- 22RE injectors
- 3VZ Popping and shaking
- Need some 1st gen parts....
- Diagnostics and humility....problems with my '86
- How often do you have to replace your TPS
- What is your project for today?
- replacing windshield washer fluid pump on 22re
- Need help with Transmission re-install
- Front Brake and Wheel Bearing Questions
- 1990 VS 1992 front grill and bumper
- Craigslist: 3vze Ivan Stewart race motor
- best place to find rebuilt 3.slow?
- 2nd Gen 4runner Pro Comp Shocks (Pics)
- is a 22re rebuild hard?
- Recently installed Boost / vacume gauge. I have some questions???
- Info on 255/85/16
- What should I ask 4 '92 4Runner?
- confused....hubs
- 22R exhaust manifold gasket quality
- Attractive aux light switch that looks OEM?
- what should i buy with $400
- VSV help
- What wire mods to run a BI-XENON setup?
- 1/2 doors
- Transfer Case issue
- 285/75 vs. 305/70
- passenger power window problem
- Hard to start in cold
- Coolant leak from Head Bolt and Water Outlet?
- deceleration backfire and engine studdering
- What lug nuts: 3rd Gen wheels on 2nd gen
- 22re rebuild
- upgrade question...
- 4runner headlights, grill, and bumper conversion ????
- IT'S GONE!!!!!!!!!!!!!!!Tell me it ain't so!!!!!!!
- coolant level in radiator?
- 2nd build-up........project Substance Abuse....
- post your ride height!! what is stock??
- Not your average A340H problems
- how can i tell what gears i have in rears?
- 1st/2nd Gens with 17" wheels
- EGR blowing oil?
- I said "LET THERE BE LIGHT" and there was light.
- w56 or G52 3.4L???
- what jack do i need?
- Stumped on starter - killing batteries
- Good mechanic in SLC
- 1991 4runner help on body repair
- Need Help With Fuel Problem
- 22re rebuild rant
- Proper oil pressure
- Marlin bumper install questions...
- mechanical oil pressure gage
- Did i get the right valve cover gaskets???
- Picked up a replacement R150F...slight differences...
- Decision Time: How much of a rebuild should I do?
- truck on side/oileverywhere, what do i need to do?
- Engine an tranny removal help
- Injector Cleaning
- No Brake Lights, Switch Good. Schematic needed
- Annoying little lurch when I let off the gas
- How much should I tighten the steering stabilizer
- infamous sunroof cover
- Electronics on airbox
- speedometer problem Help!
- Is this the starter?
- Front End Rebuild
- Colorado Trip advise,where to go?What to bring?
- Difficulty of doing a clutch, cv joints?
- Alignment issues after Steering Relay Rod Recall
- distributor vacuum tubes... thingy... confused....
- JET - Factory ECU Upgrades Reviews?
- in the market for new shocks....
- 3VZE Headers... And other things!
- Trouble at 65mph
- Do you have a 22RE LCE Performance exhaust for a Pickup?
- Gas mileage in colder weather?
- Blind spots...I cant see anything
- weird stuttering/jolting at low rpm's
- Tricks to changing fuel filter on 22re
- Broken TPS plug
- Stock rear ride height?
- 92 4Runner: No power under acceleration
- LCE Headers on a 3vze Auto
- Possible to bend a Cam Gear?
- Cleaned up the old yota
- which vac line best to T in boost guage??
- Best place to drill through fire wall ??
- Press on the Brake: Idle goes up and down
- Front crank seal change in truck?
- Brake Rotor Replacement Question
- cam for 22ret
- '93 4 Runner/3.0 V-6 Question
- anybody in Lwiston/clarkston area
- Gas mileage
- Tundra Brakes On Pickups
- w56 problems
- 3VZE-Os valves, size? etc
- 3VZE starting/stalling issue...
- Rear End Whine
- rear tube bumper ideas
- Timing chain with no bright links
- dose any one know if this will work?
- 94 4Runner Specs?
- Rear Brake Shoe Change - Now No (little) Brakes?
- rear view mirror
- 93' FSM cd iso
- Shake In steering Wheel
- Noise in 3rd and 5th gears
- Unique eBay find
- how/what should i paint my sliders
- valve timing
- wierd back end levitation
- looking for a good junk yard???
- VSS 3VZE location
- My new 94
- Hesitation in Rain (22RE)
- Metric Studs
- Head Gasket????
- rebuilt 3vze 190 hp for 2k?
- Transformation
- ARB Bumper owners
- ...and while I'm still here...
- Stock Body Stickers
- Cold Start Injector Timer
- Should I replace the headgasket or just....
- transmisson problems
- Emergency driveshaft question...
- Bought some 33's.... Now what????
- My Oil Leak (^^)
- Injector swap
- Still can't get my truck to idle!
- Tube Style Bumpers and Aftermarket exhausts
- Almost drowned it, now it won't start
- Did a couple things to my 4Runner this weekend!
- ball joint spacer question.. help
- $600 ! If you don't mind the drive?
- tru trac for 7.5 IFS
- PCV Valve Location?
- Buzzing Dash
- Are 1st and 2nd Gen Grills interchangeable?
- Tach Install (1989 Pickup 4x4, 22R/e)
- Inclinometer trade or not
- Roof Racks
- fuel line leak Help
- Looking at a '92
- 3.4 swap - wtb
- A wake up call on my 2nd gen...
- intake manifold gasket for turbo 4runner
- Arb
- 22RE tranny swap possible?
- snorkel
- Bubbly noise in my heater core
- Brake lights stick
- look what I got off craigs list
- Cloud of Exhaust after start up
- 2nd gen clock out?
- really bad knock
- torque spec question
- 22RE motor mounts
- 4runner frame same as pickup frame?
- rear spring swap question? sas 4runner
- Body lift question
- V6 to 22RE tach conversion?
- Disengaging the front differential.
- HELP!!! what am i doing wrong?!
- Exo cage
- New to early 4runners. Looking at a couple.
- ? on timing lights
- Side Mirror Removal?
- Stuck diff fill plug
- Rims And Tires
- help, miss at idle,tuneup done
- 94 toyta pulling trailer
- Why are people ignorant
- I need a wiring Diagram to install my Alarm
- 5 Minute Oil Leak?
- Do i need a new locker if i regear?
- Jardine cat-back, which cat to use
- I Give on the Transmission...Uncle!
- Starter-wont engage flywheel
- looking at 88 4runner with knock
- Factory roof racks/bars
- Looking for front skid plate help....
- Help me narrow my search for tires...
- Changin my mind about which tires again...
- 87 4runner air fuel ratio problem help please leave for bc in two weeks ahh
- Maiden Voyage
- External tach really necessary for idle adjustment?
- ring and pinion gear 3rd member
- 5 speed swap
- HElp ASAP cv install
