Need a game plan
Old Oct 21, 2007 | 10:27 PM
Djlarroc's Avatar
Need a game plan
After much researching... I have some ideas for my stock Runner, but still have some questions...
TIRES
1) 33x10.50x15's on 15x8 steelies, 4" Back space Or...
2) 285/75/16 (33x11) on 16x8 steelies, 5" Back space or 255/85/16 (33x10) Prefer just a lil' wider tire though.
*33x10 is a way more expensive tire than a 285/75-255/85 and there's less tire options...at this point though, best deal I can find will decide diameter.
LIFT
1) NO LIFT w/15" except for maybe some BJ spacers. If I get 15", I will relax t-bars for added flex.
2) If I get 16", I'll have to see what adjustments are needed and maybe a 1" body lift. As of now, my truck sits nice and straight. I don't have the sag.
ARMOR
Found some sliders for cheap. Gona get them hopefully next week.
GEARS
Got a great deal on some 4.88's for the rear. Now I need to look for fronts.
LOCKERS
Need help on which locker. Thinking of Aussie's unless they are too hard to get. I've been reading about the ordering problems. If not, then lockrites. I want to keep it simple & inexpensive.
QUESTIONS:
1) Am I missing anything on my tire choice? Will I be able to stuff the 33x11's into the wheel wells?
2) I need to look for a 7.5" for front diff right?
3) What is "third member"? and also, am I going to need to find that for the gear change?
4) How will my 5SPD/22RE drive w/4.88's on stock 15x7's w/235/75/15's? (29")
5) Since I will most likely do 1 locker, where should it go? Front or rear?
Hate to ask all these questions, but I have done ton's of research & still can't quite find my answers. Thanks guys!!
Old Oct 21, 2007 | 10:59 PM
sh0kk86's Avatar
TIRES
I was going back and forth between those two sizes as well, but in the end decided im going with the 33x10.5x15 purely because of price of 16" tires to 15" tires.
LOCKERS
im going with aussie locker for my rear.
3) What is "third member"? and also, am I going to need to find that for the gear change? third member is the whole gear housing, that bolts into the axle housing.
its going to be very torquey. just avoid highways, rpms might be to high to even be at highway speeds.
what kind of truck is it for?
if your wheeling tight trails, rocks a front locker would probably more beneficial since our ifs front ends most always pop a tire up in the air first.
Old Oct 22, 2007 | 07:22 AM
Djlarroc's Avatar
Originally Posted by sh0kk86
TIRES
LOCKERS
Really? From all the searching I've done, the 33x10x15 (BFG) is more expensive than the 16". It's for an '89 4Runner. I have read before about going w/lockers in front because of that reason. Co has TONS of rock trails. I had also read, when you lock the rear, it makes it harder to make tight turns on pavement. That sucks.
Old Oct 22, 2007 | 08:41 AM
run4her's Avatar
Yes it does i have a spool in the rear and on a tight pavement corner it looks like i am goind to tip over.
Old Oct 22, 2007 | 12:38 PM
sh0kk86's Avatar
http://www.discounttire.com/dtcs/fin...FSUV&tc=MTAVM5
http://www.tirerack.com/tires/Sizes....rrain+T%2FA+KM
pretty sure the 16" tires are more expensive
Old Oct 22, 2007 | 12:52 PM
Djlarroc's Avatar
Not quite my friend.. this is why I was thinking of upgrading.. Cheaper & more options:
http://store.summitracing.com/egnsea...=KeywordSearch
Old Oct 22, 2007 | 01:01 PM
TORTIS's Avatar
ARB front and rear. i still say buy a trail rig. write your company name all over it, and lease it to your office. then you can write off everything. i think.
(disclaimer: tortis is in no way a trained CPA, and offers bogus advice to the unsuspecting)
Redeth005
Jun 28, 2018 08:16 PM
Swampwalker
Oct 12, 2015 09:49 AM
Cycles
Sep 29, 2015 06:37 AM
yoterr
Sep 15, 2015 03:47 PM
