post your ride height!! what is stock??
Old Oct 17, 2007 | 03:58 PM
n16ht5's Avatar
ok I am curious.. I just put in my 1.5" budget spacers and cranked the front up an inch...
I sit from the coil seat to coil seat in the rear 10"
in front, from the center of where the bump stop is (on the metal) to where the bump hits 2.5" (a hair over maybe)
i have 265/75 R16 tires, and from the ground to the pinch seam on the body underneath the doors I am at 21.5"
what is everyone else at? anyone thats stock and not saggy chime in? just curious what I am at !
Old Oct 17, 2007 | 04:05 PM
GA95Runner's Avatar
from the ground to the edge of the chrome trim around my rear tire, I sit at 36.5"
Old Oct 17, 2007 | 04:49 PM
n16ht5's Avatar
what about you susp?? everyones tire sizes are different, so it changes the ground to size... im 37.5" from ground to fender lip
my fiance has a 90 with pretty much no sag...
rear coils from seat to seat is 9"
front 2" from metal to metal at the center of where the bump stop is *(front bump)
my car sits about 2.5" higher (she has 31s that are worn down and I have 265/75 r16s)
Old Oct 17, 2007 | 05:35 PM
Tofer's Avatar
Sponsor
Ground to center of front fender: 44 1/2"
ground to bottom of frame in the front: 25"
not stock
Old Oct 17, 2007 | 07:03 PM
waskillywabbit's Avatar
Ground to bottom of frame under door - 26" - 85 4Runner on 39.5 Iroks
I'm stock.
Old Oct 17, 2007 | 08:45 PM
n16ht5's Avatar
man I miss my 85..
Old Oct 17, 2007 | 09:01 PM
x-man's Avatar
i dont know....but i scrap the 6'2" height limit in parking places.
not stock.
Old Oct 17, 2007 | 10:32 PM
elripster's Avatar
I have 15" rims and sit 14" rim to fender lip in the front. Stock is 13-13.5" so I have about 1" of lift with my 1.5" BJ Spacers. My truck sits level with coil spacers and air shocks.
I'd say measure rim to fender lip noting rim size, it removes the tire from the equation when trying to asses how your suspension is adjusted against other's suspensions.
Frank
Old Oct 18, 2007 | 08:52 AM
run4her's Avatar
26 from frame to the ground by the door. not quite stock
Old Nov 6, 2007 | 06:41 PM
51's Avatar
51
i dont know if this helps but i did some research and found that some models came with 31x10.5 as an option from the factory. my 93 4runner sits from ground to the middle of the fender(in relationship to the center of the tire) front is 35.75" in the rear 33.5" wow im 2.25 lower in the rear that sucks... probably due to the 228xxx miles on the original coils and the big sub box in the back. soon i should be lifting the rear with some downey 1.5 hd coils and we will see what the after measure is.
Old Nov 6, 2007 | 07:01 PM
MIKEMOKAS's Avatar
36.5 from ground to center lip of front fender
35.5 from ground to center lip of rear fender
on 31's, and i think the previous owner cranked the tbars...
nevermind, i just noticed this was pretty much meant for 4runners... oops
Old Nov 7, 2007 | 10:17 AM
4rnr's Avatar
frame to ground=23"
37" tires
Old Nov 7, 2007 | 01:11 PM
jcfb's Avatar
From the front fender lip to the ground = 41"
From the metal directly under the door to the ground = 25"
4" Suspension lift, 33x12.50 tires.
Flying91
45
Apr 11, 2024 04:39 PM
May 20, 2016 10:27 AM
coffey50
Jul 28, 2015 10:55 AM
kcaudill
Jul 20, 2015 12:06 PM
Nickdigg
Jul 7, 2015 06:04 AM
