is a 22re rebuild hard?
Old Oct 19, 2007 | 01:30 PM
jjrgr21's Avatar
i found an 88 pick-up that will most likely need a rebuild, how hard is it? and how much would it normally cost.
thanks,
Jason
Old Oct 19, 2007 | 02:19 PM
derrik86's Avatar
its not hard at all man i did it in my garage of an apartment complex where u wil get kicked out if u just work on a car haha. i had the crank ground, block bored and honed, head had a valve job, i got a new timing cover and new flywheel and clutch and eveyrthing was new. bearings pistons pumps lines hoses o rings around the injectors and the total cost was like 1500 or something like that.
Old Oct 19, 2007 | 03:42 PM
jjrgr21's Avatar
thanks
Old Oct 19, 2007 | 03:55 PM
fillsrunner4's Avatar
easy to do its a small motor and parts are easy to get. i would go for it. take the heads to a shop to get surfaced and if you really want the block to get honed but you can also just use a drill and a honer to DIY. great experience too and saves tons on labor
Old Oct 19, 2007 | 04:22 PM
jjrgr21's Avatar
thanks, i'm debating on extended cab .vs. reg cab now.
bigjstang
Jun 2, 2025 03:56 PM
young buck
18
Aug 27, 2018 02:40 PM
coleypull15
Nov 3, 2015 07:41 AM
jerusry
Oct 19, 2015 05:28 PM
bryan34w
Jul 6, 2015 05:53 PM
