removing ac?
Old Oct 21, 2007 | 07:45 AM
87turbo's Avatar
removing ac?
okay so my 4runner is just about ready to have the rebuilt motor dropped in and i was wondering if there were any benifits to removing all of the ac stuff. The 4runner is my winter rig and i daily drive a motorcycle in good weather.
87 turbo 4runner BTW.
Old Oct 21, 2007 | 08:29 AM
moses's Avatar
If you do remove the system i would be interested in picking it up from you. (i'm not going to answer you question though. i'm probably biased!
moses
Old Oct 21, 2007 | 09:26 AM
thefatkid's Avatar
pro-you might save 15-25 lbs.
con-A/C is good in cold weather also, it help to dehumdify the air. I use the A/C all the time when it is wet to keep the windows clear.
Old Oct 21, 2007 | 11:57 AM
87turbo's Avatar
and what about removing the EGR? besides cleaning up the engine bay....
Old Oct 21, 2007 | 12:02 PM
OSU4Runner's Avatar
Removing it will save you some weight, probably 35lbs at best and will free up some horsepower since the compressor will be removed. I removed the A/C on my old Integra Type R. Had a supercharged B18...had no need for A/C. I couldn't really tell the weight was gone, but could definately feel the freed up horsepower.
Old Oct 21, 2007 | 04:40 PM
n4ynu1010's Avatar
What about when you take your girl wheeling with you and yall get stuck and have some free time and you need to de-fog the windows when rescue comes ???
You need the A/C then
Or what if she says "Hey baby lets go wheeling" on a hot summer night ????
Old Oct 21, 2007 | 04:41 PM
n4ynu1010's Avatar
If your not using it , no horsies being used
Old Oct 21, 2007 | 04:42 PM
n4ynu1010's Avatar
Remove the EGR !!
They are evil lean burn lobbyist's
Old Oct 21, 2007 | 05:13 PM
SCYOTA's Avatar
If it works good why take it off? Whats to gain by removing it unless it doesn't work?
If you do decide on removing it you should get some shorter bolts because the bolts that normally go through the bracket and timing chain cover will be too long. Just go to your local drealership and have them print out a diagram of the timing chain cover. You will see that there are 2 different bolt options for those holes.
Old Oct 21, 2007 | 07:33 PM
bob200587's Avatar
EGR is important. I wouldn't remove that.
Old Oct 22, 2007 | 12:59 PM
n4ynu1010's Avatar
Egr
Important ??????
Not to the engine it isn't and to be honest it doesn't make that big of a emissions difference either , I know alot of peeps that live in northern Va that pass sniffer without them all the time , remove it and it will increase your mileage and give you a tad of high rpm pep.
Old Oct 25, 2007 | 09:43 AM
bob200587's Avatar
Originally Posted by n4ynu1010
Important ??????
It keeps the temps inside the cylinders down and that's quite important. I could care less about the emissions aspect of it. If anything it would decrease your MPG.
Old Oct 25, 2007 | 09:53 AM
n4ynu1010's Avatar
I have heard that claim about temps but it is like the Ozone , depends on who you want to lean with because the evidence of that is marginal at best .
mulewright
Sep 28, 2015 10:27 AM
gyroscope7
7
Sep 27, 2015 08:39 PM
LotOMiles
Sep 14, 2015 11:45 PM
Rickstwowheels
Sep 9, 2015 06:12 PM
gp66
Sep 7, 2015 08:29 AM
