Almost drowned it, now it won't start
Old Oct 13, 2007 | 07:01 PM
Shoua's Avatar
Here's the short story:
I went into the river a little too deep...got out and it ran okay. I started to drive back, when suddenly it dies. I have spark, and I have fuel, but no ignition. I just got a new battery for it, since I cranked the hell out of the old one and killed it. The motor is not frozen, since I can still turn the crankshaft by hand. I just drained all the fuel; it had about 2-3 gallons of water in it. The coil, distributor, and spark plugs are dry. The ECU is good, it didn't touch the water. All fuses are good. One day it cranked when jumped to my car, now it won't even crank, even with a brand new battery.
Any suggestions? I can't figure out anymore. My head is spinning and I'm getting really frustrated! Help!
Old Oct 13, 2007 | 07:04 PM
ozziesironmanoffroad's Avatar
replace your distributor, your dis cap, spark plug wires, etc. see if that works. and if its carburated, spray the guy down with carb cleaner. oh, and if its fuel injected, try the stuff you spray into the intake to get the engine to start. if it has spark, try that.
Old Oct 13, 2007 | 07:08 PM
Shoua's Avatar
Everything is dry. Oh yeah, I forgot to mention, it's the 22re.
Old Oct 13, 2007 | 07:15 PM
did you try ether, or other intake chemicals that force the engine to start? also, just cuz its dry doesnt mean its good, are they getting power? are they functioning? id try the ether first, and if it dont work, then check out the other stuff.
Old Oct 13, 2007 | 07:28 PM
Shoua's Avatar
Haven't tried that stuff yet. Right now I'm trying to get all the water-contaminated fuel out of the motor (with the spark plugs out of course). Then I plan on installing fresh plugs and gasoline, but I can't even get it to crank yet. I don't want ignition right now, just for the starter to crank. After that I will worry about everything else.
Old Oct 13, 2007 | 07:29 PM
4rx's Avatar
4rx
check the starter
Old Oct 13, 2007 | 07:31 PM
yeah, if anything run a wire directly from the battery to the starter just to crank it. like, hook it up to a switch or something so you can flip it when you want.
Old Oct 13, 2007 | 07:32 PM
Shoua's Avatar
That's the next thing I was planning on checking. Could I have possibly "fried" the starter by cranking it a little too much?
Old Oct 13, 2007 | 07:36 PM
4rx's Avatar
4rx
or a bad ground..check that as well.
Old Oct 13, 2007 | 07:44 PM
refried's Avatar
Did you overheat the starter and cook it?
Old Oct 13, 2007 | 07:47 PM
881stGenRunner's Avatar
]if yo\u got any water in the engine makke sure you change your oil as well
Old Oct 13, 2007 | 07:49 PM
you might have fried it. does it click, or does it not do anything?
Old Oct 13, 2007 | 08:38 PM
Shoua's Avatar
It doesn't do anything. It doesn't even click. I can hear the starter solenoid click, but none from the starter. I will wire it straight to the battery again, and see if anything happens.
Old Oct 13, 2007 | 08:42 PM
notanymore's Avatar
2-3 gallons of water in the gas? that would be my guess as to why it might of died, did you make sure you are getting spark? my shop teacher always would say if it doesnt start, check the FACTS Fuel Air Compression Timing Spark. my guess is its either fuel of spark problems. dont forget to change your oil and you might want to think about changing it in your diffs too, if you dont have extended breathers on them.
Old Oct 13, 2007 | 08:48 PM
Targetnut's Avatar
If it is a 4cyl pull the number 4 spark plug, if it is a 6cyl pull number six.
Put a long skinny screwdriver down the hole and slowy crank it by hand. If the screwdriver goes up and down as you turn then proceed with other testing. If not your engine is broke
Old Oct 13, 2007 | 09:23 PM
Shoua's Avatar
The engine turns by hand (and by that, I mean with ratchet and socket). Have extended breathers, but the whole rear end was under the water for about 1 and a half hours. I know there is water in the rear diff, but water didn't reach the front diff breather.
Right now my problem is not fuel or spark, but the starter not cranking.
Old Oct 14, 2007 | 05:17 AM
Targetnut's Avatar
if it locked up a rear cylinder it may have broken the crankshaft and you would be able to turn the crank by hand but the back part could still be locked up.
This is not the most likely scenario, in fact I don't recall ever seeing it happen on a Toyota just some other brands. But it could happen. And it's easy enough to check for.
Old Oct 14, 2007 | 08:45 AM
n4ynu1010's Avatar
Starter/Starting Problem
Have you checked the ECM/EFI Fuse , maybe got some water in a plug and blew fuse - of course you said you had fire so I guess that wouldn't be the issue but there are other fuses that control ignition / starting functions
Old Oct 14, 2007 | 08:48 AM
n4ynu1010's Avatar
I believe there is a Ignition Fuse that would prevent the Ignition Switch from actuating the solenoid on the starter , usually that dark colored 7.5 Amp fuse , check that one if you havn' t
Old Oct 14, 2007 | 08:20 PM
Shoua's Avatar
n4ynu1010, I've already checked ALL the fuses. All fuses are okay.
