EGR blowing oil?
Old Oct 17, 2007 | 12:25 PM
co4rnr's Avatar
EGR blowing oil?
After I have spent quite a bit of time getting my idle problem taken care of, I discoverd a new problem.
My truck has been using quite a bit of oil even though I just re-built it. I think I found the reason. When I had the truck running, i noticed a loud noise coming from the back of the valve cover where the EGR is. I noticed there was a lot of oil on the injector below the EGR. I pulled off the vac line that goes to the EGR and it was pumping out oil mist.
I searched and found that the EGR should not be a culprit when looking for an oil leak. Does anyone have any idea of how the EGR is supposed to work?
Old Oct 17, 2007 | 12:41 PM
jason191918's Avatar
does this help
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Oct 17, 2007 | 12:52 PM
co4rnr's Avatar
Synthetic oil to blame?
Originally Posted by jason191918
Thanks Jason,
Upon further inspection, I think I have a much bigger problem on my hands. I think the plate behind the valve cover is also leaking. There is also seapage where the head meets the block. I also think the oil pan is leaking a bit.
This is all after I switched to Mobil-1 Synthetic. could this be the reason?
Old Oct 18, 2007 | 10:22 AM
co4rnr's Avatar
Does anyone know of a great mechanic in the Colorado Springs area?
Old Oct 18, 2007 | 11:34 AM
natedawgg94's Avatar
hey if you have the time i would try to fix these problems on your own. no time like the present to get dirty. JMO
dumpster84
Apr 30, 2016 06:03 AM
Dakotaneu
Jul 27, 2015 12:03 AM
montanatruck
Jul 25, 2015 03:45 AM
HookahRoo
Jul 20, 2015 07:06 PM
87blyota
Jul 10, 2015 04:31 AM
