Gas mileage in colder weather?
Old Oct 15, 2007 | 07:34 PM
Firebb15's Avatar
So 2 weeks ago i was driving my 94 4x4 3.0 5 speed pickup up north to my cabin in northern MI with my quad in the back doing about 72mph with the cruise set. I filled the tank and checked my gas mileage after the 230 mile drive, i had 19.3 mpg. So last weekend i did the same exact trip again (with the same quad), except the 80 degree heat spell we had was gone. I want to say it was around the low 50's. I was only doing about 68-69 mph with the cruise set again. Both trips were done late at night, so traffic was not an issue. I got 16.4 mpg. I thought i was going to get a little better the second trip because i was a little slower. I know wind can be a factor, but it was about the same both trips. Could this be from the 30 degree difference? I know cooler temps mean more oxygen=more fuel=more power. Does 3 mpg sound about right?
Old Oct 15, 2007 | 07:41 PM
toyotatom93's Avatar
I cant answer your question, but I say next time you try it cover the grill with something like cardboard or those store bought covers and see what you get for mpg.
Old Oct 15, 2007 | 07:51 PM
stormin94's Avatar
You should be getting better MPG in the cooler weather, because it is more dense, and the fuel will burn better. I dunno, maybe going slower hurt your average if you went up a lot of hills.
Old Oct 15, 2007 | 07:58 PM
Tylercs's Avatar
I know there are summer gas formulas and a winter formula. The winter stuff is supposed to reduce emissions at the cost of MPGs during colder operating conditions. I don't know when each starts being used but it is getting to be winter.
Old Oct 15, 2007 | 08:07 PM
infiltrator's Avatar
i know what you mean. once i went on a trip and i got like almost 250 miles to a tank, it was unreal i was smiling all day driving that thing..
next freaking fillup it didnt even hit 200.... maybe 170 before the light came on...
id say its maybe the cruise control. i know sometimes with mine it wines (to higher rpm's) wayyy too much, and it sucks gas like no other...
and other times, its a good ride, hitting 2000 rpms 2500 at peak...
anything else like ect power on or off? overdrive?
Old Oct 15, 2007 | 08:19 PM
InternetRoadkill's Avatar
I would suspect changes in the fuel blend myself. Perhaps the gas had alcohol in it.
Old Oct 15, 2007 | 08:26 PM
YodaPala's Avatar
Awww yeah this is awesome is'nt it?
Old Oct 15, 2007 | 08:29 PM
Firebb15's Avatar
i always fill up at the same station (the one a mile from the house). I doubt that my rpm's going from 3,100 - 2,900 really made that much of a difference in climbing hills? Next time i'll do the exact same speed and see
Old Oct 15, 2007 | 08:34 PM
dropzone's Avatar
Fossilized
I don't know about Michigan but in Oregon during the winter they have this Crappy Oxygenated Gas they make us use November 1st to February 28th. It has got 10-15% Ethanol in it. My mileage always sucks running this stuff.
Old Oct 15, 2007 | 08:44 PM
longhungsilver's Avatar
wow why do they make u use 10-15% ethanol in your gas??
Old Oct 15, 2007 | 09:09 PM
Ethanol has a lower energy content than gas, so the mileage sucks when using it.
Old Oct 15, 2007 | 11:08 PM
stormin94's Avatar
Oh yeah, I forgot, In warmer weather, your tire PSI goes up, and when it gets colder, it decreases. Maybe it's got something to do with your tire pressure. Also, for who said that the winter gas burns cleaner than summer gas, at the cost of MPG, I think it's just the opposite of that. It makes sense that they would want to decrease emmissions in the Summer time when pollution is worse, rather than in the winter when the weather prevents pollution build up. At least it's like that here.
Old Oct 16, 2007 | 04:45 AM
fredtheturd's Avatar
I get better gas mileage at 2 weird times...cruising around base at 20-30 mph and when it's scorching hot outside. I am north visiting family & on my trip up, I got 14 mpg vs the 16 I normally get in Alabama. I also get that 16mpg mixing in about 28% ethanol. Been running that way for over a year now with no problems at all. So when my gas mileage went to crap on the first tank along I-65, I tried filling up with straight Shell gasoline in northern Alabama & had the same results.
Old Oct 16, 2007 | 05:07 AM
MMA_Alex's Avatar
a lot of states in the northeast have banned mtbe, and they pretty much all use 10% ethanol now.
Old Oct 16, 2007 | 08:21 AM
n4ynu1010's Avatar
Yep 10% Eth here in Va and the mileage reeks , check your tire pressure and a slightly higher rpm can make a significant difference in regards to engine power/fuel usage on the highway
Old Nov 17, 2007 | 12:26 PM
rustyrunnerboy's Avatar
would the rpm be a factor??? i am under the belief that there are more efficient rpms, if you are too low then it has to work hard to get up a little hill etc and too high and it's well, just too fast...i usually try to keep mine between 2500 and 3000...does that make sense???
Old Nov 17, 2007 | 02:02 PM
Firebb15's Avatar
Ya that makes sense. I usually try to keep it under 3,000 for fuel economy and even more so in windy conditions.
Old Nov 17, 2007 | 02:06 PM
Greg_Canada's Avatar
I always get worse mileage in colder weather, but i feel a power increase too.
I lose 2+mpg in the winter months.
he's gone
7
Dec 3, 2019 07:08 AM
accuracy
Aug 30, 2015 09:47 PM
raptor510
Aug 19, 2015 02:15 PM
Tacoma1313
Aug 17, 2015 05:44 PM
nonstop
7
Aug 11, 2015 09:26 AM
