Best place to drill through fire wall ??
I am trying to install my mechanical boost guage where would be the best spot to get through the fire wall??
if at all possible I would try going through an exsisting grommet in the firewall. If not. Make sure you find a place that is easily accessible from both the inside and out. Near where the steering column goes through the firewall maybe?
Make SURE you use a grommet,silicone, or whatever to seal up that hole!
the grommet that has the tach wire and ECU harness running through it, on driver side. piece of cake. just take a screw driver and pry an openning, then stick a wire through
