Electronics on airbox
Old Oct 16, 2007 | 01:03 PM
ochs99's Avatar
I have a 86 4Runner with a 22rec engine, and I'm planning on putting a open element(K&N) filter on it, which will take a bit of modification. My question is, there is a electronic hookup on top of the air box, is this the air temp sensor? What effect will it have if I unhook this? Is it a nessasary to have, or can I run the open filter set-up without it? Is there also a air flow sensor that I will have to worry about as well?
any advice, input, etc would be great!
Old Oct 16, 2007 | 01:23 PM
InternetRoadkill's Avatar
The box is the airflow sensor. Disconnect it and your engines dies.
Old Oct 16, 2007 | 01:36 PM
ochs99's Avatar
so if I build a new box to hook to the K&N and have this sensor as a part of it, it should still work?
Old Oct 16, 2007 | 02:23 PM
TORTIS's Avatar
it works off a flapper type butterfly. i have seen on some rigs where they run K&N filters, but i don't know how they get around mass airflow sensor. the butterfly is built into the top of the airbox, i think.
Old Oct 16, 2007 | 02:38 PM
just a 22re's Avatar
this is whatyou do as i did just what your trying to do ok go to autozone or something like that go into the tunner (honda lots of sound but car goes nowhere) alse and look for a mass air flow adater cant spell lol its round and has a few holes in it on the flat part and its about 20 bucks you redill the holes cause the toyota air flow is smaller use the gaskets and bolt her up and there you go oh and the air flow just unbolts off the air box ver easy
Old Oct 16, 2007 | 02:44 PM
TORTIS's Avatar
come to think of i guess they do unbolt,since they are replaceable.
Old Oct 17, 2007 | 06:32 AM
The air flow assembly is removable from the airbox. But I don't know why you would want a K&N filter under the hood. It will suck hot air from the engine compartment and K&N filters are not very good at filtering.
Old Oct 17, 2007 | 06:37 AM
mt_goat's Avatar
X2, don't put on a K&N. Worst filter out there.
Old Oct 17, 2007 | 10:21 AM
ochs99's Avatar
ok, seems the advice is to stay away from the K&N. what about the "deck plate" mod for improving airflow. Or maybe a additional airflow tube into the airbox?
Old Oct 17, 2007 | 12:08 PM
mt_goat's Avatar
That's a better idea, I'd see if you can get a tube to breath from inside the fender. That's what I did when I moved my airbox to the other side for a 3.4 swap:
A 3.5" hole was cut in the inter-fender for the air supply:
I cut a 3.5" rubber flex coupling from the plumbing dept at Lowes to seal up the hole and keep the engine breathing the cooler air outside the engine bay:
Here's a view from inside with the turn signal removed:
https://www.yotatech.com/forums/f116...tml#post981811
justdifferentials
14
Jun 11, 2017 08:36 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
toyotasaurus
Sep 24, 2015 03:30 PM
Rickstwowheels
Sep 21, 2015 05:21 AM
matt1833
Sep 16, 2015 07:11 AM
