Removing valve covers?
Old Oct 22, 2007 | 04:11 PM
Tacoma750's Avatar
Can you remove the valve covers on a motor without hancing to change the oil or do anything serious? I KNOW its a stupid question..but im tryin to clean my buick3800 up a bit, and this is the first time ive ever taken Valve covers off. Thanks guys
Old Oct 22, 2007 | 04:18 PM
mikes19984x4's Avatar
i would think that you wouldn't have to change the oil every time you remove the valve covers, as there would be no loss of oil when you did it. just don't let anything get in there to contaminate anything. just my 2 cents...hope it helps.
Old Oct 22, 2007 | 04:27 PM
fillsrunner4's Avatar
no oil will need to be changed cause the oil after the motor is off all falls to the bottom. keep the work area clean and dont let anything fall into the heads and youll be fine. Be sure to replace the gasket with a new one
Old Oct 22, 2007 | 04:34 PM
Tacoma750's Avatar
ah I didnt know there was a gasket...Figures theres more than just unbolting and rebolting back on
Old Oct 22, 2007 | 04:43 PM
you can pick up the gasket from like schucks and napa. make sure you replace it its important anytime you remove a part with a seal or gasket.
Old Oct 22, 2007 | 07:50 PM
longhungsilver's Avatar
i assumed you were taking the valve cover off to replace the gasket
Old Oct 22, 2007 | 07:51 PM
Tacoma750's Avatar
Im actually taking them off to paint them...
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
Sep 4, 2015 09:27 AM
irritech
Jul 27, 2015 05:15 PM
calderp
Jul 27, 2015 09:58 AM
keithporter83
Jul 18, 2015 12:37 PM
