94 toyta pulling trailer
Old Oct 12, 2007 | 01:11 PM
dcmbsc's Avatar
I have to go 1 hour 30 min drive and pull a small trailer with my yota v-6 auto , would my truck be able to handle this load and how anhything else u recomeaned i do?
Old Oct 12, 2007 | 01:19 PM
Victor's Avatar
I say yes as long as you aren't planning to put a lot of weight on the trailer.
Old Oct 12, 2007 | 01:29 PM
BigWavePaul's Avatar
Cool Tire Pressure
Check the lights on the trailer and make sure that you wired them right
Check your Tire Pressure, low pressure causes bad gas mileage and could result in a blowout
Make sure you have the right trailer hitch with a good ground, my new hitch was fresh and the paint kept me from getting bright lights on the trailer until I grounded the trailer to my bumper
Use your CB if you have one
You'll have no problems if you maintain the truck right. My 94 p/u 22RE pulled a loaded 6'x12' Uhaul trailer, 3-4k lbs, from Colorado to Alabama (27 hrs, normally 19) with no issues-Safety 1st!
Old Oct 12, 2007 | 04:14 PM
leebee's Avatar
thats quite a feat for the little 22re! my v6 had some issues with a 16' trailer weighing in at 3k lbs, just under the rated tow capacity.
lee
Old Oct 12, 2007 | 04:15 PM
chimmike's Avatar
I had no problems towing approx 5k lbs for 45mins. Of course, I didn't go any faster than 60mph at any given time....and I wouldn't do it very often at all.........just keep your speed down and keep overdrive off and you'll be fine. Overdrive once at a set speed might work, but it'll constantly kick down a gear...I just took o/d off for most of it.
Blamalam
Mar 12, 2022 07:34 AM
58rennur4
Aug 4, 2015 08:49 AM
shadowbirdie
Jul 21, 2015 10:38 PM
Jeffreynmandy
Jul 18, 2015 08:26 AM
toyota32
Jul 6, 2015 05:42 PM
