so i think i blew up my motor today.... now what?!
Old Oct 20, 2007 | 03:59 PM
Tofer's Avatar
Sponsor
Went wheelin today at Tahyua. i entered a puddle that was deeper then i thought (another guy was playing around in it on the other side and wasnt as deep) water went over the hood and up to the windshield when i entered and then my 35s disappeared. the truck then died gracefully. as if i had stalled it. pull me out pulled the spark plugs and tryed to turn it over only to find a loud cruch and then grinding noise. then we tried pulling me to get the crank to turn. the wheels would lock and skid. dragged it out the the paved staging area, drove down to get cell service to call AAA. came back and tryed dragging it again, this time in 2HI 4th gear, STILL the wheel locked and wouldnt turn. any ideas it wont turn the crank even wiht all the plugs pulled? what did i break?
Old Oct 20, 2007 | 04:04 PM
Albert.G's Avatar
take out your plugs and let it air/dry out for a day or so, then put some gas in there, put the plugs back, BAM we have ignition
Old Oct 20, 2007 | 04:07 PM
lethe's Avatar
connecting rod maybe?
lethe's Avatar
its acting like its hydrolocked with the plugs removed. i dont think that will help.
Old Oct 20, 2007 | 04:08 PM
Tofer's Avatar
Sponsor
connecting rod broken then jammed?
i have pics of the whole event.... and i was wheelin with one of the local afternoon DJs and he said that this will give him alot to talk about on monday... so now the whole seattle metro area will hear about it... lol
Old Oct 20, 2007 | 04:11 PM
Albert.G's Avatar
same thing happed to my dub, dont ask, same , couldnt crank it at all with the plugs out, let it dry for a day, put some gas in the cylinders, fired right up
Old Oct 20, 2007 | 04:39 PM
Corey's Avatar
Co-Founder/Administrator
Sorry to hear that Chris.
By radio jockey, you must mean Rob from 100.7?
http://www.fjcruiserforums.com/forum...a-10-20-a.html
Just saw his thread a bit ago.
Old Oct 20, 2007 | 04:50 PM
Tofer's Avatar
Sponsor
he's the one..... rob the Possum ...
remember those are 35s...
the rest of the pics are here:http://photography.eakland.net/home2...007/index.html
Old Oct 20, 2007 | 05:34 PM
lethe's Avatar
it looks pretty deep there.
Old Oct 20, 2007 | 06:10 PM
reggie 00's Avatar
See you should have stayed down here.
Where you dont have web feet and hydro'd motors.
See if it will dry out and put some gas and oil in the cylinders try to hand crank and if you get any movement let it rip and see what happens. cant really break it any more than it is can ya.
good luck.
Old Oct 20, 2007 | 06:12 PM
OSU4Runner's Avatar
Wow that sucks bro......
Old Oct 20, 2007 | 07:12 PM
AH64ID's Avatar
Man that sucks.... probably a rod. How many rpm's when it died?
you gonna 3.4 it?
Old Oct 20, 2007 | 07:59 PM
MudHippy's Avatar
Wink
Get the BIG can of WD-40 and spray the hell out of everything that could possibly be full of moisture. It won't harm anything and is perfectly safe to use on electrical connections too(non-conductive). It's excellent for removing water from where it shouldn't be.
Hint:The "WD" stands for "Water Displacement". That is what it was made for, displacing water on/in mechanical and electrical equipment. Specifically developed for the U.S. armed forces to use on ballistic missles, but it works on trucks too.
Old Oct 20, 2007 | 09:19 PM
InternetRoadkill's Avatar
Arrgh. Why do people do that to their trucks?!?!?
Old Oct 20, 2007 | 09:26 PM
BC_4runner's Avatar
What, take thier 4x4 and go 4x4?
Old Oct 20, 2007 | 09:32 PM
rowdy235's Avatar
man that sucks. I honestly have to say from the way it died it doesn't sound serious- but it looks like i may be wrong. Good luck and I'll hope for a good outcome.
Old Oct 20, 2007 | 09:33 PM
FredTJ's Avatar
That's not 4x4'ing.
That's mistaking their 4x4 truck for a submarine.
Pretty silly...
You don't need a 4x4 for that, you need platoons and outriggers.
Fred
Old Oct 20, 2007 | 09:38 PM
Tofer's Avatar
Sponsor
ya when it died it bogged out and died.... it felt like it stalled. no big bang, pop crunch or pop.
ya and i hate water / mud. and this confirms it. snorkel is coming next.
Old Oct 20, 2007 | 10:32 PM
thefatkid's Avatar
Was the air filter soaking wet? You know the stock intake is directly behind the driver headlamp.
I've seen a couple of rod let go on 3.0l, I'm not sure if the rod broke or the failure was the nut/stud.
That much water could have killed the starter. Can you crank it over with a socket/wrench on the crank pulley?
Old Oct 20, 2007 | 10:37 PM
thefatkid's Avatar
That tells me you threw a rod or bent on and it is jammed against the block. I'd look for a new engine.
