3VZ Popping and shaking
Old Oct 20, 2007 | 09:44 AM
4Run_95's Avatar
The engieen start to pop (from the exhaust) and it shakes a bit when it revs, from about 1000-2800. At higher rpm (over 2800) it dissapears. Idle is fine. Cant notice anything in gear. Shifting is also hard sometimes. Sometimes, when going slow in 1 gear, the "walk" is "unsmooth" as if you where "shaky" in the right foot.
Any help would be gold!
Old Oct 20, 2007 | 12:42 PM
MudHippy's Avatar
If the popping is happening when you decelerate while in gear, as when engine braking occurs, then your dashpot may be bad. Or may need adjusted. It could also cause the 1st gear idling crawl to be jumpy(unsmooth) like your not working the throttle soft enough(shaky with right foot). Try turning the adjustment screw on the throttle in so that it moves toward the plunger of the dashpot. Do a little at a time and see if it helps. The adjustment makes the dashpot engage sooner, if it's functioning properly.
I don't have any ideas on the engine shaking. My 3VZE does the same thing. I've just gotten used to it, it doesn't bother me now. I think it's probably the way they're built, very "buzzy" engine.
Old Oct 20, 2007 | 09:58 PM
4Run_95's Avatar
Thanks for your answer. I havent notice any popping when deacelerating, only when in neutral. Could it still be the DP? Might it be a burnt valve? Hope not...
Old Oct 20, 2007 | 10:04 PM
MudHippy's Avatar
No, only if when decelerating in gear, not in neutral.
Burnt valve? I hope not too.
How is your ignition? Is your timing correct? Are your spark plugs and wires in good order?
Old Oct 20, 2007 | 11:15 PM
stormin94's Avatar
M guess, timing is off, bad coil, or ignition. Maybe fouled plugs.
Old Oct 22, 2007 | 03:59 AM
4Run_95's Avatar
Well, its time to change the plugs soon so that might be it. I hope its that simple...
Thanks for your tips!
matmattmatthew
10
Feb 9, 2021 04:15 PM
calderp
Nov 16, 2015 02:49 AM
BK2TFUTURE
Oct 11, 2015 08:42 PM
Rerun
3.4 Swaps
Oct 1, 2015 12:24 PM
mluz013
Sep 29, 2015 05:53 PM
