Picked up a replacement R150F...slight differences...
Old Oct 16, 2007 | 06:35 PM
LS1Steve's Avatar
I dropped the tranny/tcase in my 1990 and am swapping in what i believe is a 1995 tranny/tcase. They are nearly identical with the exception of a sensor and something shown here I believe...I don't have the unit in front of me but this is where I think it was in the pic, what is this???
Old Oct 16, 2007 | 08:08 PM
RobD's Avatar
Can't really tell from your pic. Any way you can get a better shot?
Old Oct 16, 2007 | 08:12 PM
Jay351's Avatar
I wonder if it has anything to do with the switch to electronic speedo's in 92.
Old Oct 16, 2007 | 08:34 PM
pennywize's Avatar
yeah, in 92 or 93 they switched to an electronic speed sensor.
maybe swap your transfer case onto the new transmission?
if you separate the trans and case i would change the seal at the rear of the trans also.
Old Oct 16, 2007 | 08:36 PM
LS1Steve's Avatar
i'm not there now and won't get a better pic till friday, but I don't think its a speed sensor, its a large part roughly 4'' by 3'' and is bolted to the case, looks like some kind of actuator of some sort. I wish I could find a pic of a unit or a part diagram somewhere somewhere.
some type of synchromesh mechanism??
Old Oct 17, 2007 | 08:17 AM
4sknrnnr's Avatar
Don't swap t-cases just to change to a mechanical speedo - just swap the speed sensors - literally the mechanical one bolts up to the same place as the electronic one.
As far as what you're pointing out - I can't make it out in the pic
Old Jan 10, 2013 | 03:46 PM
big1000's Avatar
oh man, I have this same problem!!! did you ever figure out what the mechanism is???
MO transplant
Apr 23, 2023 11:58 AM
mskalmus
May 28, 2017 07:51 AM
Daneums
Aug 20, 2015 05:36 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Jnkml
Jul 6, 2015 01:20 PM
